how to remove rear trayling arm bush on a cosworth
the OE bushes are metal sleeved, they rust making them very hard to get out of the arm itself.
If you knock the rubber part out you can cut the sleeve with a hacksaw, you should be able to close it up and push it out. Becarful not to cut into the trailing arm though.
the best way is with a big hydraulic press, thats what i use now
![Cry](https://passionford.com/forum/images/smilies/icon_cry.gif)
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
The proper cosworth trailing arms are a spherical bearing.
The poly ones are just a piece of polyeurethane.
Ford saw fit to spec a proper bearing for the cosworth (poverty sierras just had rubber bushes) - I can't see how replacing them with some poly is going to improve things!
Neil.
Neil.
Originally Posted by abdr500
Kevin Sharp
please explane
please explane
they are a cheap alternative if you cant afford the originals though
Nope. For the reasons above.
If you insist though, find a local engineer with a fucking big press, they don't come out easily (or so I hear - I have the superior part
Neil.
Neil.
RichardPON
edit it as i ment are the polly bush good for any bushing. my car is fully bushed but ther other motor isnt and was gona change them all with polly
jessie_rs
11
03-06-2019 04:57 PM
155lee
14-08-2015 11:21 AM
track.focus'd
12-08-2015 05:53 PM
