Problems with cossy TB & Vauxhall TPS
I knew it! I knew i would run into some sort of problem with this atsome point
The vauxhall TPS won't fit on the cosworth TB, its totally the wrong way round, its far too small, and its doing my head in
Anyone got any suggestions at all? are the cossy & vauxhall throttle position sensor the same inside?
please I'm desperate, meant to be rebuilding the top end this week!
Originally Posted by rsnissan
can you not fabricate a bracket to help it fit? any pics of the tps?
See, its totally out I know there are quite a few people using the cossy inlet on their LET's but i can't get hold of any of them to ask what they did
http://img372.imageshack.us/img372/4275/cimg22975ze.jpg
Originally Posted by Garage19
I suspect both the TPS's will give the same 0-5v signal so just use the cossie one.
If you want to check just get your multimeter out.
I'm trying to think what the vauxhall one is Some of the vauxhall TPS are just a switch, they are either on or off. Then there are the other type that measures each move. If you know what i mean?
I take it cossy ones are 3 pin aswell?
There are a couple of choices of cossie TPS, might get lucky with one being the same as yours. (rwd and 4wd work back to front to each other)
Stu or SECS will know the details of the cossie one (voltage range/resistance etc), someone on mig will know the same for the vaux one.
I don't go on mig no more though, so can't ask
So there is a difference between the 2ED and 4x4 TPS? I know no one is using motronic with these inlets, but i simply can't afford after market management right now, my court case has gone tits up see
I really must sort you out for that manifold Chip. I keep meaning to pay you for it or replace it with another, but its been so hectic round here the past few months Its even more hectic now i blew up the omega
Anyway, if anyone knows the voltage range of the cossy TPS i would be most pleased if you could let me know. Also, how would i test the vauxhall one with a multimeter? i got 3 pins
So there is a difference between the 2WD and 4x4 TPS? I know no one is using motronic with these inlets, but i simply can't afford after market management right now, my court case has gone tits up see
Get spanish fly to pop round.
Measure the voltage at the 3 pins at 0 throttle, then measure them at half throttle (ish) and then at full throttle.
I will do the same at the weekend with both types of cossie one and see if either are the same.
Dont worry about the manifold, no rush, just find me one in the new year some time.
I've just this minute got off the phone to Rob, he had a look on autodata and the readings are as follows.
Testing with pins 2 & 3:
Closed = 0.1 - 0.7v
Open = 3.5 - 4.7v
Closed = 0.1 - 0.7v
Open = 3.5 - 4.7v
one of the two cossie ones should be fine then.
I cant remember the exact details of the difference, but i think one goes to 0hms at closed and one goes to infinity (which is why you cant just wire them backwards, it reads right every except zero throttle IIRC)
given how little input the throttle actually has on that revision of the motronic though AFAIA, it should be fine if you get the right one
Post up and ask on here for what the readings are for the two types.
well thats what decent fasteners are worth
if you want something cheaper, use standard head bolts
Pfffffffffff, do i look like a 'standard' kind of guy to you Chip?
Looks like you want a 4wd cossie TPS then spence
So whats the running voltage of the 4WD TPS? 0.1 - 5v?
Also Chip, another unrelated thing...got a mail back from SBD
Dear Spencer,
No sorry but there is not one made for the later head.
Regards
Dick
-----Original Message-----
From: formmail@62.189.246.32 [mailto:formmail@62.189.246.32]
Sent: 19 December 2005 12:25
To: technicalinfo@sbdev.co.uk
Subject: Technical Enquiry
Below is the result of your feedback form. It was submitted by
(formmail@62.189.246.32) on Monday, December 19, 2005 at 12:24:48
Address: N/A
Phone Number: 1
Email Address: lightside55@hotmail.com
Car Make and Model: Vauxhall astra MK3 C20LET conversion. C20LET LATE TYPE
ENGINE (square belt drive)
Engine specification: Enough information provided above.
Use of car: Race
sales quatation request: Hello, i was just wondering if you do an ARP head
stud kit for the later C20LET engines? You only have the pre 93 ones
showing. also a quote for price. Cheers, Spence.
Regards
Dick
Address: N/A
Phone Number: 1
Use of car: Race
i dont know anything about stud kits for ecotec mate (ie after 93), sorry
Must have worded it wrong
yep, same ones
or steveboyslim ones are the other option, thats what i have gone for
Tried contacting him via PM on Mig, but got no reply
I see him from time to time i can grab you a set if you want?
What i'll do is after xmas, arrange to meet you, drop you thecash, then you can get them when you see him next. I'll get you a carvery for your troubles
I can pay for them and you pay me back after mate, thats not a problem
Its not that i never pay, its just if i have something before hand to pay for later, i tend to 'forget' or drag it out....ask DFS They were stupid enough to give me a sofa and tell me to pay next year
For my own peace of mind, i'd rather pay you first
Thanasis
07-09-2015 07:33 PM
