Mk2 Mondeo interior heater blower probs!
DEYTUKURJERBS
No matter what its set to, the fucking thing now only blows out the front screen de-mister.
Whats up with that?
My feet are getting cold
Whats up with that?
i think it is a common problem, something to do with the control board in the pass footwell i think, just do a quick serach on here as i am sure its been mentioned before
Re: Mk2 Mondeo interior heater blower probs!
Whats up with that?
Whats up with that?
DEYTUKURJERBS
ive not checked if the aircon still works as its fuckin freezing, but the heaters work at all speeds, just blow at window only!
after a while your face/head is so hot you want to turn the blowers off, but your body isnt that warm, and your feet are still freezing
was fine until i fitted a different headunit in the car, seemed to happen at same time...
PROOF, modifying your car makes it totally unreliable no matter what
https://passionford.com/forum/viewto...ghlight=mondeo
my fault was for the heaters speed, but might be the same issue????
sounds like one of the control pipes has split or come adrift at the back of the control panel, the system is vacuum controlled so it needs a supply of "air" to work, remove the radio/heater surround then remove the 3 heater controls and check all the connections for leaks(with the engine running!!)
regards,
steve
regards,
steve
Originally Posted by the youth
Steve you can type quicker!!!lol
Steve
Steve
Steve
Steve
Steve
Steve
here are some pics of our track night in july at teeside autodrome, my old mondy is on track aswell as my cossie..
http://www.cosworthrsspares.co.uk/funstuffcleveland.htm
steve
07-10-2015 12:56 PM
