Bolts loose and 1 missing on turbo/housing ! ?
Basically last week i heard something rattling from my engine ( as if something was loose ) anyways as it was dark and could not see that well it turned out to me that the the turbo damper was loose , because when i put my hand on top it stopped the noise
Soo the next day and up until now it never mde that noise again and never thought nothing else of it
So last night , went under for a look to check oil and water and all that and noticed that one of my bolts were missing where the housing bolts on to the turbo ( 4,17 mm bolts ) should these be threaded or a bolt and a nut ? and 2 were loose , so tightened up and still need another bolt and nut to get it back the way it was Not a big deal really but why would these come loose guys ? and would i be losing power from this ? and would it do any damage at all troops ?
Had to get that off my chest lol its the first problem in a while lol but defo not the last ehh
just finding my feet
if theres a air leak caused by it ( and prob will have) then YES you would loose power aswell as boost
could explain the 20psi you got, when its all done then check the boost again to be sure
Originally Posted by Jano_OddKidd
In the end you will snap the studs in the head and be in a whole world of shit...
Make sure all parts are to correct torque settings and the damper is adjusted correctly..
How many mounts do you have on the zorst system?
How many should there be and iL have a look
rab have a look where the midle box was removed, its still needs to hae the 2 mounts on that section to hold it up , some places dont do this though
JANO !!!!
i need some helicoils for a head thats got a few threads stripped as where on the same subject
PM me a price please as i know you can get all sorts of stuff
JANO !!!!
Ask me a question!
If its a YB head and the cam cap retaining threads are threaded then replace with CVH rocker arm studs and countersink the cap.
If its a CVH head what part is threaded as there is many good fixes for these..
JANO !!!!
JANO !!!!
what manifold studs for a cossie can be sorted with cvh rocker studs
ive got like 4 cvh heads lying about too
muchos appriciate
your a fooking star mate , you could have sold me some "secret" studs to fix it to earn megga cash too
seriously thanks
muchos appriciate
seriously thanks
Originally Posted by MADRod
Originally Posted by rabmc
Not sure matey its 3.5 inch mongoose to 4 inch tail
Mongoose dont do a 3.5" only a 3". Mines custom 3.5" for 700+bhp.
DavidK
27-09-2015 02:55 PM
