Question for the resident plumbers
Can anyone tell me how to get the air out of my hot water system . When you turn on the hot tap in the kitchen it spits at me
for some reason it seems worse in the evening
bloody things driving me mad
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
Originally Posted by focusv8
Combi boiler or hot water storage tank?
Hard or soft water area?
could be quite a few reasons, like vent pipe off cylinder to small should be 22mm the vent pipe allso needs to be rising up all the way to the cold water tank, but if you only have this problem with just that tap it could be that where the hot water pipe is joined to the main pipe work, that conection is in the vent pipe and so it is drawing air down the vent pipe when you open the tap or that air that is being vented is geting traped in the pipe work to that tap. Try just opening the hot tap about half way and see if it still happens as it wont try and draw air in if the flow is not as great
Cheers Dunc. As you may know i,ve bought this house to raise funds to get my shop open and although there are numerous things i need to get done to it this tap is probably the most annoying
The plumbing was all replaced about 5 years ago by the previous owners son and so probably isn,t quite up to scratch
Cheers for the suggsetions ,i,ll investigate !
