Help with Morrettes
Old Dec 14, 2005 | 07:54 PM
TrevCos's Avatar
TrevCos
Default Help with Morrettes
I'm trying to wire up my twin headlight conversion, and I seem to have all the functions, but the inner lights don't light up at all.
When should the inner lights light up, and should I still be using my original sidelights?
Old Dec 14, 2005 | 08:29 PM
TrevCos's Avatar
TrevCos
Someone must know surely, and don't call me Shirley.
Old Dec 14, 2005 | 08:31 PM
Alvyn's Avatar
Alvyn
mine come on main beam and when you flash head lights,side lights are in the outer ones on my saf DONT know about on escos but would think that you still use the original ones as well
Old Dec 14, 2005 | 08:35 PM
TrevCos's Avatar
TrevCos
The main beam still seems to be on the outer ones for some reason. I thought the inner ones should be the main beam, but why it's not I'm not sure.
Old Dec 14, 2005 | 09:17 PM
Azrael's Avatar
Azrael
TrevCos main beam is in both outer and inner ones. Are those new style MOrettes? I have manual for those on my computer.
The wiring if you have complete setup is pretty strraightforward.
Old Dec 14, 2005 | 09:22 PM
rstoughy's Avatar
rstoughy
Also both your original sidelights and the outer ones on the Morettes will come on with the sidelights. Thats why people tend to paint the original jobbies the body colour
Old Dec 14, 2005 | 09:24 PM
Azrael's Avatar
Azrael
I don't have sidelights IN the Morettes conected at all. Those are for normal Escorts rather then Escos.
Old Dec 15, 2005 | 07:07 PM
TrevCos's Avatar
TrevCos
Yes, my sidelights come on with the outer lights. And main beam comes on the outer lights, but I can't seem to get anything on the inner lights. I wonder if it's just a bad earth or something.
Anyone who has a wiring diagram, that would be great.
Old Dec 15, 2005 | 07:50 PM
EssexMikeSi's Avatar
EssexMikeSi
i had this problem wen i put morettes on my mk6. my inner lights didnt come on wen they should on full beam. i think it was summit to do with the wire that runs from the side with the relay on, to the other side. ie got the wires round the wrong way coz sometimes wen i put full on only one side would work with the inner one on aswell yet other side still didnt
Old Dec 15, 2005 | 09:36 PM
Damo V's Avatar
Damo V
have you given the relay a perm live and earth?
Old Dec 15, 2005 | 09:37 PM
The Sludge's Avatar
The Sludge
garibaldi
any good for you matey
http://users.telenet.be/shauni330/Es...PJ-Anglais.pdf
Old Dec 16, 2005 | 04:11 PM
TrevCos's Avatar
TrevCos
The Sludge, thanks for that. There's obviously something not right somewhere then, because I'm doing it exactly as it says. On the drivers side inner light, I've got two wires coming off it, and one I've connected to the blue long wire coming across from the other unit, and the other I've made an earth lead for, and attached it to the bodywork. Is that right?
Does it matter which lead goes to which wire on the inner lamps?
I've got nothing from either of the two inner lamps though, and I've been trying allsorts today. I wonder if the relay's blown or something.
Any ideas anybody. That'll teach me to buy them secondhand! What a faff!
I assume you can't get these relays easily can you?
Old Dec 16, 2005 | 04:17 PM
The Sludge's Avatar
The Sludge
garibaldi
NO PROBLEMS. How about emailing them?
http://www.morette.com/
Old Dec 16, 2005 | 06:12 PM
TrevCos's Avatar
TrevCos
I think I will do. Thanks for that mate.
Old Dec 16, 2005 | 06:25 PM
The Sludge's Avatar
The Sludge
garibaldi
Old Dec 17, 2005 | 07:19 PM
Damo V's Avatar
Damo V
Relays are standard issue items any local shop can sort
dans rst
Apr 30, 2009 09:05 PM
Cozzie Bhoy
Ford Escort RS Cosworth
16
May 18, 2006 09:10 PM
manoj
Feb 7, 2006 11:22 AM
RS_JAY
Jan 18, 2006 06:03 PM
