cams
Old Jul 13, 2004 | 04:22 PM
cosworth-daddy's Avatar
cosworth-daddy
Default cams
does anyone know the price of a piper cams kit for a sierra saff cosworth 1991
Old Jul 13, 2004 | 04:32 PM
Karl's Avatar
Karl
Norris Motorsport
Depends what you want.
I put kits together myself either using my own cams or any of the known BD range.
You have several options for various kits starting with re-ground cams only using std springs, right up to my high spec ground from blank's complete with 380lb double race valve springs and new followers. You also have the choice of solids or hydraulics so the list is extensive. If you require more info email me direct, otherwise if you know what you want from piper just call them direct.
Old Jul 13, 2004 | 06:42 PM
cosworth-daddy
i have around 500 pound to spend on a kit i went some that will work well with these engine mods, T4,green inj,rs500 intercooler,3bar map sensor,viper air filter, exhaust, adj boost,group a head gasket.
more on the 0-60 side would be best
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
