Turbo converting a xr3i EFI cabriolet???
right got a xr3i 90spec cabriolet and its EFI from factory.
How hard would it be to make the car efi turbo using fiesta turbo running gear?
Is it simply a case of just replacing the ecu, map sensor, edis for the frst items and plugging the frst engine bay loom in aswell?
Then put the FRST engine and turbo etc in? or have i missed other important things?
cheers, hope u can help
ah hah i see.
Is it a bigger pain in the arse to turbo it with erst running gear. Mates got all of a frst sitting in his drive an i can get it cheap sorta thing, so giving it great thought now, lol
nice one
or pm, roughly wat i need to look out for or remember or do as i'm online til late anyhows
nice one
yes u can use ur efi loom in there now just need to swap a few wires and put a frst map sencor ur need to cut wire from std xr3i one and need change fuel pump as its only 1bar a cossie one will do or frst
so need to get a frst fuel pump or a saph cos one that bolts underneath the car like on mfi erst's?
cheers
so what'd be better getting a ofac ecu, map sensor OR ofab ecu an map sensor?
should be able to get both
cheers
Matt Baxter
16-09-2015 09:30 PM
marky_g
15-08-2015 11:43 AM
