Why is my cossy smoking ???
Its nothin too bad as its had a recent engine and turbo...
When rolling down hills in say third gear using the engine to brake, when you get back on the throttle it gives a puff of blue smoke but then clears pretty much straight away.
Could this be the valve stem oil seals leaking ??
Thanks in advance
Thanks in advance
Originally Posted by R4N S S
they all smoke, but if you had an engine just done surely the stem seals would have been changed anyway.
This all happened before i got the car though you see so i cant be certain.
Like i say just wanted to know if id got any problems
Originally Posted by Beach
Originally Posted by pee vee
have you got a middle box in your exhaust?
ive read, and heard it said that the turbo relies on a LITTTLE back pressure to keep the oil on board (backpressure caused by middle box i guess!?)
so if you aint got it,, on over run like you describe, that COULD well be
why it does it!!
why it does it!!
yeah mate.
i mean, according to this tuners mag i was reading
it says the turbo seals rely on some back pressure to keep the oil in,
so maybe just the back box isnt enough?
dunno, i was skeptical too till the guy that rebuilds turbos
on here posted about it too
EDIT: but as damo and others have said, could well be the stem seals/turbo. but seems odd if they are all new.
was a werid one ay beach. was kicking out quite a bit when u went down my hill after dropping me off
Dunc
p.s. it still was fucking quick as Mr yellow scoob found out ay mate
Dunc
sounds silly but is every thing still bolted tight to where it should be mate
i would expect a little poof of smoke on over run just build up of burnt gases and fluid in the exhaust? ever noticed someone driving down the road with back box having a pee same thing i believe
2Evos & 1 Escort Van :-)
Mine used to do this a fair bit - had new Stem seals and brand new turbo.
On my old chip it did it a lot, and flamed A LOT.
Now on new chip and same turbo / engine and no smoke and very little flames. I know you said blue smoke (suggesting as per others Stem seals or turbo oil seals), but this is what mine did and was pretty much entirely over run fueling (part of the way the chip is set up.)
Sounds like you need a flamer kit fitted to burn off that nasty smoke!
Simon
Simon
Originally Posted by cossiecrew
beach you forgot to add it stinks of fuel all the time
Dunc
Dunc
I know that it is mapped to have plenty of fuel as well but still think its oil, its only when you go back on the throttle after using the engine brake, fitting a new breather soon so ill just see how it goes
1 Post
mine does the same with new exaust guides and stem selas, and turbo seals done, no smoke when idle or on power, just likeu say on over run down a long hil, then when u open teh throttle, a quick whiff of smoke then clear againb,
like aabove, its a cossie, and mine does have the centre section to my mongoos btw
0-60 in 17 seconds (eek)
Originally Posted by Dave Henshall
mine does the same with new exaust guides and stem selas, and turbo seals done, no smoke when idle or on power, just likeu say on over run down a long hil, then when u open the throttle, a quick whiff of smoke then clear againb,
Dunc
strange to me mate but dont say i didnt warn ya dont want to be reading a its gone up in flames post
Dunc
I think its un burnt fuel that you can smell in the exhaust but i couldnt be sure
Beach
WHat fuel lines do yuo run? std or aftermarket, as non PTFE aeroquip, "bleed" petrol fumes
gibbo frst
No dont worry, agreed turbo does require a little backpressure, but I wouldnt worry about it IMO
gibbo frst
[quote="Damo V"]Beach
All standard stuff mate not done anything witht he fuel lines at all.
Which are the ptfe type then Damo ??
Originally Posted by Damo V
Just more rigid than the "normal" aeroquip thats all
sounds like the problems i had, a little blue on the overrun or when u pull up to a junction after a good thrashing, started off very light but within a month u couldnt see behind you for the white smoke! allthough its blue smoke id say its your pistons but i could be wrong as im no expert
The rings are passing or the pistons are fooked from being melted ??
My bezzer mate had this problems and thought it was stem seals , but he was getting a large amount off smoke once he went back on throttle turned out to be rings
Sure he will reply to this to tell it a bit better
the mahle pistons in your cossie are 10 times better than the standard nissan shite so i wouldnt worry about it mate.
what about worn valve guides??
would this not let oil run down the valve and into the combustion chamber?
was the head defo a full recon??
Im sure it never used to do it before i went stage 3, maybee its having a hard life and just wants a re build.
Im going to see Karl in the new year im sure he can tell em what it is as im not going to worry about it just yet, all i want to do is ensure ill be ok for the ring trip next year
Cheers people
Its been rebuilt 13k ago with new 4x4 mahle pistons and rings so id be gutted if it were that.
Cheers for the advice mate
