Ticking me off!!!!!!!!
Hydraulic lifter ticking its tits off all the time. Anybody direct me in the replacemnt of the buggers?
Cheeeeers!!!!!!!!!
Cheeeeers!!!!!!!!!
Not really anything to it mate, you just whip off the cam cover, take out the cams, remove the lifters with a magnet, and "repacement is reverse of removal"
Obviously you need to time the cams in properly after, is that something you are familiar with doing?
Originally Posted by Stu @ M Developments
But whatever you do dont use a magnet near the new ones.
BTW you can clean them if you can be arsed!
I always use a magent, even on ones i have then put back in again but its an extremly weak one on the end of a pen type thing that i use.
Does a strong magent effect their future operation then?
Valve grinding stick sound a good option though, as obviously that wont effect anything
Its a very small issue indeed, but a valid one....
Magnetising any part of the engine will encourage small metal particles to accumulate on them and obviously a cam lobe then coming crashing down on it at mach 10 will encourage somewhat more wear than is acceptable.
As i said, small point but valid.
Ah fair enough, the magnet i use is so weak it only just picks them up, literally have to try a few times to pull them out with it, so not much chance of magnetising them, but will swap to a grinding stick just in case
Mind you, impacting anything steel/iron can encourage it to become magetised too cant it IIRC from a level physics, in which case to be really fussy you should make sure you lifters never see an impact, like from a cam lobe, lol
