smoke when i lift off but stops when i excelerate ??
my zt is smoking when i take it for a hard thrash in 4th to about 6.2k rpm then drop a keg for engine breaking and it snokes untill i press the excellerator
when i lift off the cars behind tend to back off alot because its pretty damn smokey and if i jab on and off it leaves indian smoke signals down the road
apart from that it never smokes
could this be the oil seals in the turbo?
the zetec head had done 80k when i had fitted it
the head was drilled for cvh exhaust stud pattern and went through to some oilways
is it possible when leting off with the turbo still spinning its's causing a vacume in the ex manifold and sucking some oil through the threads?
Steve Escos
01-10-2015 06:57 AM
