Are Reno & Vauxhall wheels swapable?
yes.but the hub centre is bigger on the reno and thet stick out more.also they torque steer like a twat cos the offset is wrong and vauxhalls are very sensitive to this for some reason.
bryan
bryan
AS above...
you can, but it won't handle as well...
The offset effects your suspension gemotry in ways you can't eaily dial out (assuming the suspension is std ish stuff!).
Alex
Alex
Chip,
I don't mean to be rude but do you have any automotive qualifications?
Not sure having a long tounge or being striagth makes you either an automotive industry profesisonal or a qulaified engineer.....
Originally Posted by SPADGE
What Renault wheels and what Vauxhall ones exactly?
could be carlton ones which are a totally different offset to astra/nova 49mm ones, or it could be 5 stud ones.
PassionBMW.com Member
Steelies from a Reno 19 onto my new Vaux Cav 1.7TD....so i'm sure I can cope with the adverse torque steer
Basicly, the Cav I just got has crap tyres, the Reno19 has new ones....so want to swap them.
Would make life so much easier if I could just swap the wheels, rather than have to stick the 19 on axle stands, while i take the set of wheels down the garage for them to be swapped over......
Adam Graham
06-09-2015 06:04 AM
