Cossie problem
Old Dec 4, 2005 | 01:27 PM
NMS Badboy^NUTTER^'s Avatar
NMS Badboy^NUTTER^
Default Cossie problem
Over the last couple of months i've been doing up my mates cossie that's been off the road for 6 years. I've just come to a point to start her up and she's running on one cylinder
Number 1 has a spark but not the others, and when winding over with the plugs out i only seem to be getting fuel from number one cylinder
Any ideas??
Old Dec 4, 2005 | 01:29 PM
RANJ's Avatar
RANJ
not an expert but injctors ???????????????
Old Dec 4, 2005 | 01:33 PM
NMS Badboy^NUTTER^
But what about the spark?
Seems strange to me that number one seems to be ok with fuel and spark, which makes me think crank sensor orphase sensor
Old Dec 4, 2005 | 02:05 PM
phil robson's Avatar
phil robson
has the engine just been rebuilt?
crank sensor gap?
is therea pulse at injectors?
good luck
Old Dec 4, 2005 | 02:30 PM
NMS Badboy^NUTTER^
no. the engine hasn't been rebuilt.
Old Dec 4, 2005 | 03:33 PM
Matt's Avatar
Matt
Old Dec 4, 2005 | 03:46 PM
NMS Badboy^NUTTER^
Old Dec 4, 2005 | 03:50 PM
PaulCossie's Avatar
PaulCossie
sounds like it could be crank sensor, phase sensor, an ecu fault , dodgy connector or ignition module...
I use one of those diagnostic widgets, give you a fault code! worth a tenner i reckon
good luck
Old Dec 4, 2005 | 03:51 PM
Ginge !'s Avatar
Ginge !
just finding my feet
if you swop leads on the dizzy cap does number 1 still fire only
Old Dec 4, 2005 | 03:53 PM
NMS Badboy^NUTTER^
Yes mate
Old Dec 4, 2005 | 04:05 PM
Ginge !'s Avatar
Ginge !
then i say its some sort of electrical/mechanical fault
hows the screenwash level, may as well check that, then you can achive somink today
in a serious note swop ecu's and get dingy to check the loom
Old Dec 4, 2005 | 04:06 PM
Stu @ M Developments's Avatar
PassionFords Creator
Have you touched the Phase sensor John? Sounds like teh polarity is inverted...
Old Dec 4, 2005 | 04:09 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
stood 6 years check the multiplugs on the wiring harness near the bulkhead.0
Old Dec 4, 2005 | 04:15 PM
Lloyd's Avatar
Lloyd
inverted polarity ? how does that happen?please explain it in simple terms .
Old Dec 4, 2005 | 05:49 PM
Graceland's Avatar
Graceland
Team HOTHOT!
someone plugs the phase sensor in the wrong way inside the dizzy
Old Dec 4, 2005 | 06:19 PM
Ginge !'s Avatar
Ginge !
thats simple enough for even me to understand
Old Dec 4, 2005 | 08:47 PM
Matt's Avatar
Matt
correct way...
Old Dec 4, 2005 | 08:48 PM
Lloyd's Avatar
Lloyd
thanks graceland.
Old Dec 4, 2005 | 08:56 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
ask your tuner
on a serious note i dont know without having a ganders
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Thanasis
Sep 7, 2015 07:33 PM
routemaster
Sep 7, 2015 05:27 PM
