distributor timing
Old Dec 3, 2005 | 09:45 PM
sufsRS's Avatar
sufsRS
Default distributor timing
how do you set up the timing on the distributor of an escort rs turbo, i changed the distributor as the other one got fooked, normally theirs always two marks that line up but this dizzy hasnt got one! im guessing its out because ive noticed a flat spot whilst coming on boost am i right? thanks in advance
Old Dec 3, 2005 | 09:52 PM
Wazzzer's Avatar
Wazzzer
get yourself a timing light matey, you can't second guess it. Sounds like yours is out if its got a flat spot...
Old Dec 3, 2005 | 10:23 PM
sufsRS's Avatar
sufsRS
cheers for that, is it meant to be set at 12 degrees btdc
Old Dec 4, 2005 | 08:42 AM
JesseT's Avatar
JesseT
12 degres btdc at the crank at under 800rpm and the vacuum pipe disconnected.
gcfcos
88
Sep 15, 2015 03:48 PM
Marino
Sep 12, 2015 11:10 AM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
