Sierra 3dr 205 Block....How Strong???
Hi,
After reading through some posts it seems theres no clear limit what these will take. People change them for the thicker walled 200 block but why??
How can the block get damaged?
I remember collins doing a 480bhp 3dr in ff or pf and it lasted years.
What bhp are you running on your 205 block?
Regards
Neal
Regards
Neal
Ive raced 400bhp cosworth for years , one engine did over 40 races on a wire rung 205 block and a T34 . However , i fitted a T4 to a 205 blocked engine earlier this year and killed it in 15 mins during qualifying at Silverstone , qualified 3rd of 38 cars and the fucker split on the in lap meant i didn't race !! I will never use an over stresses component agin , its simply not worth it .
Originally Posted by marco polo
Hi
theres a lad on here called deano and he had about 480/500+bhp using a 205 block he never had a problem they are not as weak as peeps make out
cheers marco
cheers marco
So would you rather have a 20 year old 205 block or a brand new 200 block?
...the early 200 blocks are weaker than the 205's by all account!!!...Use only the lastest 200 small turbo block if you want the lastest and strongest evolution.
But its like asking the impossible half will say bollocks the rest will big it up and this is from TUNERS...so the true answer to this qustion is TRY IT!!!Shouldnt have to be like that but its the way it is as no 1 tuner will ever agree with each other!!!
Totally agree with what Martin has said about the risk factor but also if Lee (Tib) is happy to run one in his car knowing how much punishment he gives it and also a lot of others do the same then the old 205 block must still be doing something very right so what do you do ? Hard one to call really
Only time I personally know of a 205 block failing is on the saff in my sig, Andy's car. the original block ended up with 6 cracks all around the bolt areas and had to be binned. Car was only running about 260bhp if that at the time but the block was of unknown age, milage etc and he had done about 18 or so track days with it since buying the car. Since been replaced with another 205 block, car is running around 300-320 bhp not that much I know but its solely used for trackdays and gets abused no end has done about the same number again without any problems at all so with this and seeing plenty of other cars I will be keeping my 205 block in my own track car
Different for everyone though I suppose
Marco 2 of the cracks ran right down the outside of the block, could have been saveable as you said but at forty quid for another 205 then it aint really worth it mate
His new block is studded but not long studs, seems to be coping very well though
We aint going for big BHP at the end of the day, just durability really.
David,
i'm not using one in my car,,,
its my bro's car and we had this conversation ourselves and said "right, lets try it and see"
the engine is together and the uprated parts are being fitted over winter hopefully,
the aim is a 400bhp/400ftlb engine with a 100bhp/ftlb nos as the engine has not been built to take high rpm's but we're gonna give it one hell of alot of abuse just to see how long it lasts doing 11.** qtrs???
"PROJECT WRONGUN" is born lol
http://www.carportdevelopments.co.uk for updates in the new year
David
the blocks are not scrap even if they crack around the bolt areas
all you would have to do to get around this if you wanted to use the block again is get the block long studed
My 205 block was rebuilt & has a 1mm overbore. Paul Hills live mapped it on greens & t34 about 21psi, he told me not to go any further power wise as it is on a 1mm overbore & could cause probs with the block.
Simon.
Simon.
