advice
Old Nov 29, 2005 | 07:39 AM
kurdt5's Avatar
kurdt5
Default advice
need to know if ive been shafted.
my head went (oil seal broke and welded on to the head)
so got a stage 2 head, had that put on, but now the car just turns over whereas it started first time always.
RAC said its not turning over fast enough to start
could it be down to the cam??
this stage 2 head had done 300 miles but stood about a year.
could this be the problem?? it had no oil inside of it.
any help would be apreciated before she's garaged
Old Nov 29, 2005 | 11:43 AM
NUTS RuS's Avatar
NUTS RuS
Is it timed up correctly ?
Old Nov 29, 2005 | 11:55 AM
DazC's Avatar
DazC
Is the battery charged up?
How old is the starter?
Old Nov 29, 2005 | 12:27 PM
kurdt5's Avatar
kurdt5
she's timed propally, new battery, starter was rewired im may.
when turned over it goes to fire up then just turns over.
Old Nov 29, 2005 | 12:32 PM
DazC's Avatar
DazC
Is there spark at the plugs and fuel at the injectors?
The KE jet sometimes gets airlocked if you break into it (like when fitting a cylinder head) and needs bleeding like a diesel fuel system. Crack all 4 injector pipes off on the meter head and get someone to crank it over while you watch for the air coming out. When it is just fuel flowin out, tighten the pipe and see what happens. You may need to do that several times. Mine had been in peices for 4 years and took a lot of fooking about to get all the air out of the system.
Old Nov 29, 2005 | 12:44 PM
kurdt5's Avatar
kurdt5
thanks buddy, i'll give it a go.
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
