803's ?????
Old Nov 23, 2005 | 12:04 PM
Franco's Avatar
Franco
Default 803's ?????
Had the car upped to stage 3 last week by Harvey ( top bloke as always!) Goes like stink.
But................
When speaking to Harvey he advised me not to hold her open at full throttle on motorways for too long etc because its 803's which are fooking pistons left, right & centre. Obviously i'm heeding Harveys warnings as he is my tuner of choice / knows the engine!
But (again)..........
Would it of been a better option to go for a set of light blues / remap?!?!
DISCUSS
Old Nov 23, 2005 | 12:09 PM
...yes light blues is a must for held top speeds imo....unless you run the greens at a max 20psi!
Old Nov 23, 2005 | 12:10 PM
Franco's Avatar
Franco
it peaks at 1.9 Bar & holds 1.7 if that helps (on the Defi's)
Old Nov 23, 2005 | 12:13 PM
Franco DONT hold it flat out....why Harvey sets it up to that is odd
...if you doin lots of high speeds max 20psi in 4th/5th gear on greens.
Old Nov 23, 2005 | 12:20 PM
Franco's Avatar
Franco
Well he knows the Comp ratio's etc, as he had to skim it / pocket the pistons.
Just wonder why so many people go down the 803 route if there's that much of a problem. In hindsight i would of gone down the blue's route..............But thats how it goes! See what happens after xmas i suppose.
Old Nov 23, 2005 | 12:24 PM
Alloy's Avatar
Alloy
What CC are the light blue's??
Old Nov 23, 2005 | 12:25 PM
Franco's Avatar
Franco
Pass Phil will know!!
Old Nov 23, 2005 | 12:45 PM
Disabled Account's Avatar
Disabled Account
Light Blues are 437 cc/min (part number 0 280 150 400), these are known as "Motorsport 400's", very good spray pattern and reccomended for power outputs up to 370 BHP.
FYI:
Greys are 503 cc/min (part number 0 280 150 403), described as "competition only", and good for power outputs up to 420 BHP.
Old Nov 23, 2005 | 12:52 PM
gurnE's Avatar
gurnE
803's are 382cc/min off the top of my head
Old Nov 23, 2005 | 12:55 PM
Franco's Avatar
Franco
So my 803's are being pushed to the limits then??
Old Nov 23, 2005 | 12:57 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Jase,
Harvey is wise to advise you that, and it is good advice for any injector that is maxed out, as there is not enough margin left in the fuelling to use this to help cool the pistons, and you're still running relatively high compression. What this will mean is that the cylinder temps will gradually build up to the point where det sets in and BOOOOOOOOM .
Obviously you could have the car set up for high speed runs, but this would mean a boost curve that dropped off considerably at high rpm. However, this would require a LIVE map to det check and adjust flat out at Brunters. It can't really be checked on the road (safely), so the advice is good for ANY off the shelf chip.
Greens are 382ish...
Old Nov 23, 2005 | 01:06 PM
Franco's Avatar
Franco
I suppose what i should really be asking is should i be keeping her below the 100 mark then, or is it ok on 2/4 or 3/4 throttle.
Better be safe than sorry, and i want to learn!! Before i get ribbed!!
Thinking about track days, the ring etc really.
Old Nov 23, 2005 | 01:09 PM
Mike Rainbird
Caraholic
Jase,
What Harvey means is no trying to redline it in fifth or holding it at 6k in this gear for any length of time (as your car hasn't got the power to redline in fifth ).
Old Nov 23, 2005 | 01:11 PM
Its not speed related, its amount of time spent at the top of the rev range.
gurnE's Avatar
gurnE
Nailing your car is fine, it's holding it flat out which is the issue here.
If it's gonna melt, it will do so on a top speed run for the reasons Mike has given ( (C) H. Gibbs)
Drive it normally, nail it around all you like but don't hold it a full throttle for long periods of time, thats all
Ps
if you have a "group a" head gasket, your pistons should be fine whatever happens
Old Nov 23, 2005 | 01:25 PM
Franco's Avatar
Franco
Ps
And that's supposed to mean what chip.
Old Nov 23, 2005 | 01:26 PM
Franco's Avatar
Franco
Funny little fecker aint ya!!
Old Nov 23, 2005 | 01:28 PM
Mike Rainbird
Caraholic
Ps
Probably he means that the headgasket would let go first . However, I have found that it is a gradual process and the YB611 lasts 8-12k depending on use (read abuse).
Old Nov 23, 2005 | 01:29 PM
Franco's Avatar
Franco
You Auto bod's love to tease!!
Old Nov 23, 2005 | 01:39 PM
Gregs's Avatar
Gregs
what about the abuse they take on track days is that ok cuz changing rpm offten?
Old Nov 23, 2005 | 02:32 PM
Alloy's Avatar
Alloy
Thank's Doug.
So, can you overfuel if you use injector's that are too large for your application?
Sorry for all the question's, just trying to learn more.
Old Nov 23, 2005 | 02:33 PM
Franco's Avatar
Franco
Think thats why you'd need it live mapped mate................................Don't quote me though!
Old Nov 23, 2005 | 02:34 PM
Sorry if that was cryptic, yeah i meant that if you start leaning out the headgasket will go before the pistons.
It was 50% true and 50% just me having a pop at fibrous gaskets for no justified reason simply cause thats the sort of arsehole i am
Ie they are bad, but not as bad as i make out
Old Nov 23, 2005 | 02:36 PM
Franco's Avatar
Franco
Douch bag!
ENGLISH MUTHA FCUKER..................DO YOU SPEAK IT!!
Old Nov 23, 2005 | 02:37 PM
Well the problem you have there, is finding an ECU that would allow you to lower the boost over time spent at full throttle.
Its not really something you can map around when you are right on the limit of flow for the injectors.
Only ways to make it safe are:
dont hold it flat out
change the injectors and remap
lower the boost at the top end
Harvey has set it how he thinks it will suit YOU, if it was someone who he thought would ignore him and sit flat out, he would have tailed the boost off and lost that person power in the interests of reliability probably.
Old Nov 23, 2005 | 02:43 PM
Franco's Avatar
Franco
Don't get me wrong chip i do listen, i always try to hold it on 1/2 throttle while over say a ton.
Anything below that, she gets a beating!!
Unlike some, i need to preserve this engine. So have to ask stupid questions etc!!
Old Nov 23, 2005 | 02:45 PM
There are no stupid questions, just stupid people asking them
Seriously though, you sound like you will be fine cause you actually not only listen to what you are told, you then go and learn about the reasons why, tuners dream come true
Old Nov 23, 2005 | 02:48 PM
Franco's Avatar
Franco
Still wonder if i would have been better to just go light blues & remap.
But i suppose i can look into this after the new year etc. Want to sort the transmission next & diffs (3.9)
Mike Rainbird
Caraholic
That's the worse thing to do, as the fuel enrichment is mapped on throttle position, so give it BEANS (just don't hold it flat on fifth at high rpm for an length of time ).
Old Nov 23, 2005 | 02:49 PM
Stu @ M Developments's Avatar
PassionFords Creator
sounds like you will be fine cause you actually not only listen to what you are told, you then go and learn about the reasons why, tuners dream come true
Agreed.
Its all to do with the Induction Stroke timebase.
Essay Chip, or shall i do it his time?
Old Nov 23, 2005 | 02:51 PM
Franco's Avatar
Franco
Agreed.
As they say in Snatch....
STOP WITH THE FOREPLAY MULLET
Old Nov 23, 2005 | 02:56 PM
Franco's Avatar
Franco
OK.........
Say i'm at the ring, coming onto the long straight, red mist, wanna give it some top end(humour me BTW FFS!!)..........................
Do i have to worry about me fooking a piston halfway down.
Signed
STOOPID
Old Nov 23, 2005 | 02:58 PM
Agreed.
I'll do one...........
Old Nov 23, 2005 | 02:59 PM
OK.........
Signed
STOOPID
and i'll answer that after ive done the PCP essay
Old Nov 23, 2005 | 03:00 PM
Franco's Avatar
Franco
Seriously
Knowledge is power!!
Old Nov 23, 2005 | 03:02 PM
Gregs's Avatar
Gregs
Ok what about on way to show, 90ish for half hour then scoobi comes past giving it the biggun, ok to floor it to 140+ ?
Ok Chip, ive got a few i did on another forum saved in Word on Fuel Pressure and erm summat else (I forget) so i will make some techy topics for PF
Old Nov 23, 2005 | 03:03 PM
Franco's Avatar
Franco
Thats another good one! Lets face it we're all red blooded males (& girls!!) here
