who's had IMBERTIGO?
Morning, just a quick question and would like to know if any of you lot has ever had Imbertigo before?
If you have could you tell me what treats it and what to recommend?
I take you mean "Impetigo" if so the google throws this up
"Topical antibiotic ointments are very effective for staph impetigo (which is more commonly seen around the nose and on the trunk or arms). Bactroban ointment is the most effective topical antibiotic. It can also work for strep impetigo (more commonly seen on the legs, in the diaper area, and on hot, moist skin), but failures and relapses are more common. Bacteria live under the yellow-brown scabs. If these are present, they must be removed in order for a topical antibiotic to work. Soaking in warm water with a liquid antibacterial soap is usually effective in removing them, but gentle rubbing is sometimes necessary. Oral antibiotics are a faster and more reliable therapy in stubborn cases of impetigo. The other medicine you mention, Elocon, is a topical steroid. This does nothing to fight infection. It reduces redness and inflammation, but the impetigo is likely to become even worse once you stop using it."
You spelt it wrong!!!!! Don't go kissing anyone untill it goes away, it's an infection where the skin blisters. Read the below.
http://kidshealth.org/parent/infecti.../impetigo.html
Impetigo is a skin infection that is generally caused by one of two bacteria: Group A streptococcus or Staphylococcus aureus. Impetigo usually affects preschool- and school-age children, especially in the summer months. A child may be more likely to develop impetigo if his skin has already been irritated or injured by other skin problems, such as eczema, poison ivy, insect bites, or skin allergy to soap or makeup.
When impetigo is caused by Group A streptococcus, it begins as tiny blisters. These blisters eventually burst to reveal small wet patches of red skin that may weep fluid. Gradually, a tan or yellowish-brown crust covers the affected area, making it look like it has been coated with honey or brown sugar.
Impetigo that is not caused by Group A streptococcus is usually caused by Staphylococcus aureus. This type of impetigo may cause larger fluid-containing blisters that first appear clear, then cloudy. These blisters are more likely to stay intact longer on the skin without bursting.
Signs and Symptoms
Impetigo may affect skin anywhere on the body but commonly occurs in the area around the nose and mouth. Impetigo is characterized by blisters that may burst, ooze fluid, and develop a honey-colored crust.
Impetigo may itch, and it can be spread by scratching. The infection usually spreads along the edges of an affected area, but may also spread to other areas of the body.
Contagiousness
Impetigo is contagious. Children can spread impetigo from one area of the body to another when they touch themselves with fingers that have been in contact with scratched, infected skin. When someone has impetigo, the infection can spread to other household members on clothing, towels, and bed linens that have touched the person's infected skin. It can also be spread among playmates or classmates who come in contact with infected skin.
Signs and Symptoms
Contagiousness
Originally Posted by JamesRSTurbo
I spose antiboiotics will do the trick?
yeh in know its a bit of a weird q 2 ask on a car forum but, thought id say
thanks 4 ur help anyways people. have an appointment tomorrow
#1 in Spelling Club
I had it years ago (when I was about 13). It started as what looked like a Spot or Cold-sore and basically grew to about 3 or 4 cm in diameter. Luckily mine didn't get too out of hand, it just felt dry/cracked and very sore. It makes you feel like shit if it is visible.
I was also told at the time that it can be quite serious. Apparently people have had it grow over eyes or nose etc. Don't know how true that is though.
Get it treated ASAP.
Good Luck at the doctors
Don't bother going to see your qualified doctor!
Take the advice of a a few people you've never met on a car forum and utilise that advice as you see fit.
