Changing from 4-5 stud!
Old Nov 21, 2005 | 08:06 PM
bradfincham's Avatar
bradfincham
Default Changing from 4-5 stud!
Right on the kit car were using 4 stud sierra rear hubs, with the plug in drive shafts.
Were looking to change these to 5 stud, still retianing the plug in shafts and the same ZF adjustable slip diff.
Is this possible?
Ps we have the drum setup now but going to the 5 stud will be cossie rear discs, but we need 5 stud hubs with the plug in shafts!
Sorry if this in the wrong forum but wanted to generate interest and also didnt know which one to put it into
Brad
Old Nov 21, 2005 | 08:08 PM
Graceland's Avatar
Graceland
Team HOTHOT!
it is possible - you need to get the rear hubs from a Granada Cosworth - that way you will have 5 stud hubs, and vented rear disks - just like 4x4 cossie ones
Old Nov 21, 2005 | 08:09 PM
jr's Avatar
jr
dont know finchy but and TTT anyway
Old Nov 21, 2005 | 08:10 PM
bradfincham
Yeh we know about the granada cosworth ones but there the bolt on driveshafts, and we need the plug in ones if possible!
hello james hows things
Old Nov 21, 2005 | 08:11 PM
Paddy's Avatar
Paddy
Legend
PM Flashpoint, he helped do a 5 stud conversion on an RST S2 for some dude in the Surrey group if you can do it on that, anythings possible
Old Nov 21, 2005 | 08:15 PM
bradfincham
Thankyou, have PM him
Graceland's Avatar
Graceland
Team HOTHOT!
you'll not be able to use the slide in joints at the rear and have discs - but the old 2 litre ghia granadas upto 1990 had the slide in joints with drums at the back and 5 stud fittings
Old Nov 21, 2005 | 08:18 PM
bradfincham
Ah damn it,
Will be a wilwood setup disc wise on the back, but really need to retain the plug in shafts as its specific to the diff,
do people not machine them out and use different cv's etc?
Old Nov 21, 2005 | 08:27 PM
Paddy's Avatar
Paddy
Legend
thats what yer man Flashpoint did
He's probably busy out stealing peoples WIFI connections somewhere
Old Nov 21, 2005 | 08:30 PM
bradfincham
Good good, I use the astra shafts and cvs on my corsa but the corsa hubs!
I was sure you could do the same with fords
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
