fully rosejointed suspension on a road car - lifespan ?
what sort of lifespan will rosejointed suspension have on a well maintained but hard driven (my caged, stripped out, zetec turbo rs16i basically) summer road and occasional track car? will it also be too harsh with the lumps and bumps we have in our roads?
or is this sort of suspension best left to track cars with the smooth tarmac surfaces ?
talking about adjustable front tca's, and also rear suspension like the following pics which are from MEF Motorsport
Originally Posted by B8
I have a very very similar setup on my S2 and personaly dont find it too harsh on the road, like you say keeping it well maintained is the key.
Worth putting dust covers on too.
Its perfectly reasonable to use on a road car, just check them reguarly for play.
Im with Mark on that one - but it really depends on the spec of the R/J used. Stainless ones will not rust and if they are self lubricating then even better - so no covers needed.
As for life and harshness/feel, just come and book a test drive mate
A closer pic of what B8 has (but from when they were new), made them from 8 brand new Subaru rear arms and then made some solid nylon bushes in 2 halves and sleeved those with metal inserts. Simple (but expensive) to do that way, and works a treat
DazC if road noise is the only downside i come across i will be a happy man
NUTS RuS thanks again, it does look simple to do that way, but i think i'll stick to rosejointed ends. which set up is best, the modified subaru arms or the usual rosejointed ends?
Interesting to see how well this type of set up appear's to work on the rear of the 06 Spec C Subaru
Which is better.... Neither is better or worse, both do the same job. (r/j and solid bush)
Graceland
31-07-2015 10:34 AM
