convert cvh efi head to mfi ?
my mate as a big valve efi head that he wants to fit to his rs turbo is it possible to weld up the injector cutouts so you can fit the mfi inlet manifold ?
Ive done this...
All i did was get an mfi gasket and use it as a templet on some thin plate, cut the plate out and then sandwiched it between inlet manifold and head.. this did work but i would not advise it, you still dont know if your getting small air leaks. there be another option but the best is just to go efi !!!
Adi
Adi
Originally Posted by Jano_OddKidd
I have plates that have no injector cutout, which means you can use an MFi inlet manifold on a EFi head.
Post sum pics soon.
Post sum pics soon.
Originally Posted by b19bal
you know when you got a air leak as the car will always rev higher than you want
What happens if someone has turned down the idle speed, or turned the amount of fuel up or down to idle better?
