any pectel monitor experts
#203
Testing the future
Paul Ripley i don't know what the mod is exactly, but presume that you do now that you have the diagram. i could just see that there is some soldering and a link on your circuit board that are, how shall we put this politely? not factory quality
as said, the datastream from L8 and P8 is the same usually. is it just a case that the monitor is not getting power? you have 2 connectors - 1 for the datastream, and one for power.
what exactly does not work about it?
#204
My monitor only comes to life after immobilser is de-armed. P8 software AND ECU board need a mod for it to work on a P8.
A tuner wouldn't usually mod the P8 ECU unless specifically asked, although most software will be set to datastream so the tuner can diagnose faults in the future (assuming they have a Pectel monitor).
Can't remember the location on the ECU for the mod, but mine looked nothing like a 'blob of solder', and was done properly and carefully.
#206
just had another look and the stuff to the left of the 14pin chip doesn't look so good. not necessary to touch that area for pectel mod, although i know EA sometimes do something in that area but don't know why/what...
#207
if i understand it all correctly here, evry monitor can be running on p8? there is an offer to me for one wich is still running on t6, so now i'am not 100% sure what to do!?
can anyone help please?
-enrico-
-enrico-
#210
Originally Posted by Paul Ripley
Both the ECU and Monitor are with Harvey at the moment so I guess only time will tell
#214
Monte Geek
He had a pectel loom so had the connector on it for it no idea whether he had it working thou, did a search his restro a while back and there where no pics of it running and his feature in the mag doesn't mention it.. so no Idea
Harvey will reveal all tomorrow
#217
Monte Geek
Update on my Monitor!
The ECU comms mod was fine, the monitor was fine but the ECU had blown the chip that controls the Comms, WI and Purge cannister.
ECU was repaired by Pectel via Harvey and works fine now
Also I spoke to Dennis Osbourne (as per my start up message) yesterday and he said he used 10 bar VDO sensors, so I'll get one and try the Oil pressure first.
Hope to get a K-type thermocouple probe/sensor sorted aswell for the exhaust temp
My displays:-
Position 1 The map sensor wasn't connected hense the 3.21 b
Position 2 The Volt light on the front lights when it drops below 11.5v not sure the when the Temp light will show
Position 3
Position 4
Position 5 VDO Sensors not connected
Position 6a VDO sensor no connected
Position 6b VDO sensor no connected
Position 7 The button on the side was indeed to start the monitor datalogging and is shown by the green light on the front next to no.7
Position 8
Oh and It was wired for both T6 and P8/L8
My displays:-
Position 3
Position 4
Position 8
#220
but aren't you tempted to just undo the 4 screws and have a look inside (just for piece of mind purposes, or perhaps you're the inquisitive sort) and it'd just so happen that you could perhaps make a note of the switch positions at the same time......pretty please with knobs on ?
#224
someone on another thread wanted to know how to add the warning lamp to the monitor
it's wired across pin 2 (+12V in)
and pin 9 (lamp out)
on the 9 pin plug
although my monitor has it done internally rather than on the dash.
[/img]
on the 9 pin plug
[/img]
#225
on the 9 pin plug
[/img]
on the 9 pin plug
[/img]
are you sure that it´s also for 6.52 as in your manual there is only a 9 pin connector my monitor has 12 output´s, btw it´s your old monitor
and for what is the warning light you´ve show above?
cheeRS MAX
#226
Off-topic but: Can someone post the P8 Mod diagram? It's hard to see what track needs severing/modding by the previously posted pic.
Cheers.
Cheers.
#228
Originally Posted by MaxCos
UPSKI for "the original"
got no info on the pinouts on the 16 pin amp connector version
apart from I do know that 2,3 and 5 are the same as the 9-pin version
but pin 12 on the 16 way goes to ecu pin 11 whereas on the 9 way it's pin 1
but I have no idea which pin on the 16-way does the same as pin 9 on the 9-way
hope that makes sense
#229
#230
Ok, so far i know:
pin2 - +12v IN
pin3 - TXT 1
pin5 - RXT 1
pin8,9,10 is used for RS232 and 6 way connector on board (pin3,5,8,9,10)
pin6,7 oil,fuel press.
Can someone find out where the warning light´s for temp and voltage can be added
cheeRS MAX
pin2 - +12v IN
pin3 - TXT 1
pin5 - RXT 1
cheeRS MAX
#231
anybody know of 1 of these for sale as ive been looking for ages with no joy
was offered a top version with fuel & ign trimmings for 1k but a bit more than i wanted to spend?
looked at the collins monitors but they are massive and dont have data logging, and are not a straight plug in to my pectel loom monitor plug
#232
Rally nut
Wow just red the whole 7 pages, and all I got is a headache now.
More seriously, sounds like hasard to come over a proper working unit, but still as Marc I want one for the same reasons he explained about the Collins one.
Thank you "the original" for the details.
#233
little update on this, i´ve found someone who can read out from the newer chip in these monitor´s
If someone has these chip´s on board: H8/532 this may be good new´s then.
cheeRS MAX
cheeRS MAX
#238
cheeRS MAX
cheeRS MAX
how about anything else?
#240
cheeRS MAX
cheeRS MAX
