problem with rst please help
Old Nov 2, 2005 | 02:29 PM
sufsRS's Avatar
sufsRS
Default problem with rst please help
suddenly my indicators have stopped working and i noticed the temp getting high so the fans are not kicking in, ive checked all the fuses seem okay wot about the relays? this morning it all worked fine now its stopped working again, any ideas?
Old Nov 2, 2005 | 03:12 PM
adamS2RST's Avatar
adamS2RST
Default Re: problem with rst please help
I've had the intermitent indicator problem before, but your fan is not working either, that sounds like too much of a co incidence
Check the fuses again and make sure they are the correct rated fuses. Also re indicators, I'd suspect relay too, mine went on my old car, the relay box is on the back of the indicator stalk, you'll need to remove the steering colomn cowling to get at this.
Hope you get it sorted
Old Nov 2, 2005 | 03:25 PM
sufsRS's Avatar
sufsRS
found the problem seems to be the yellow relay in the fusebox has burnt a tiny bit, but now wot do i do is it a case of cleaning it up or a case of a new fuse box? just cleaned it up and it works fine?
Old Nov 2, 2005 | 03:34 PM
adamS2RST's Avatar
adamS2RST
You could just get a new relay ?
Old Nov 2, 2005 | 03:37 PM
sufsRS's Avatar
sufsRS
cheers for your replys adam thats wot i thought but surely (i hope not) their would be damage inside the fusebox, the relay isnt that badly burnt out just one of the connectors cleaned it and it works fine but dont wnat to take a risk with the fan can anyone else help? must be some sparkies on here with the day off
Old Nov 2, 2005 | 10:43 PM
sufsRS's Avatar
sufsRS
btt any more advice people
Old Nov 2, 2005 | 10:56 PM
DaveEscos's Avatar
DaveEscos
you just answered it yourself you cock
change the relay or STFU
Old Nov 2, 2005 | 11:01 PM
stevo1978's Avatar
stevo1978
on the thermostate houseing disconect blue plug briage a bit of wire in plug if it works you need new switch if not its faulty wirering or fan hope this helps you
Old Nov 2, 2005 | 11:53 PM
sufsRS's Avatar
sufsRS
Dave wots STFU mean?
Old Nov 3, 2005 | 12:06 AM
david's Avatar
david
Check the bunch of earths on the pass side inner wing, just above the horn. Ive had problems with them corroding just before they are crimped and causing bad earths.
Side repeater is earthed there and im fairly sure the fan is too.
David.
DaveEscos's Avatar
DaveEscos
Old Nov 3, 2005 | 12:07 AM
Old Nov 3, 2005 | 12:17 AM
sufsRS's Avatar
sufsRS
did not know it meant that i were just wondering why its burnt out il check these wires out davin thanks for that and daveEScos you prick if you read up you will find the question is unanswered i also asked if i will need a new relay and if the dusebox has been damaged
Old Nov 3, 2005 | 12:25 AM
DaveEscos's Avatar
DaveEscos
CAN YOU NOT READ??
Old Nov 3, 2005 | 12:36 AM
sufsRS's Avatar
sufsRS
if your not going to help and have no answers i suggest you STFU all i did was asked a couple of questions and needed abit more help or some more answrs in more detail asshole
Old Nov 3, 2005 | 12:38 AM
DaveEscos's Avatar
DaveEscos
Old Nov 3, 2005 | 12:39 AM
sorry but that pic is fucking funny as
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Old Nov 3, 2005 | 06:52 AM
adamS2RST's Avatar
adamS2RST
Don't worry about Dave, take his comments in jest mate, he's only messing
I'd just change the relay myself mate, i wouldn't worry too much if al is ok again...
A.t.p
Oct 23, 2015 07:54 PM
DAZZER
Sep 30, 2015 08:43 PM
A.t.p
Sep 29, 2015 05:04 PM
