cossie gear box
7 bolts hold the box to the engine inc the 10mm one holding the plate between box and engine + 3 starter motor ones. There are just 4 others bolting the crossmember to the chasis.
RWD Racer
Originally Posted by DAN P
does any one no how many bolts hold the box in on a 2wd saff
Originally Posted by 900ss
4 bolts hold box to bellhousing
4 nuts hold xmember to the floor
Originally Posted by SPADGE
Don't know what Matt and Wyn are talking about as there are deffo 6 main bolts holding box to engine!
Why do some people remove the 4 bolts to the bellhousing, leaving the bellhousing in there, surely its easier removing the bellhousing from the engine the normal way
Wyn that is a shite way of doing it imo
If your going to have the box out its well worth removing it complete with bell housing and check the clutch etc....
RWD Racer
Unless something else needs changing or inspecting then no need.
Adam Graham
06-09-2015 06:04 AM
