UPDATE- Gasket needed between turbo+turbo elbow?
DEYTUKURJERBS
On RS turbos, is there a gasket between the turbo and the turbo elbow?
And do you need one?
Its same on my S13 and id prefer not to run one as its one less thing to blow.
Ignore posts below as they not related as ive changed the question!
DEYTUKURJERBS
Right, its on my 200SX, as the turbo-manifold join has a metal gasket and it blew in half, so dont want to fit one if i dont bloody need to.
Also the turbo exhaust housing has a similar end to it like a RS Turbo with an elbow section before the downpipe- can i run that with no gasket too?
It has a metal one again, but if i dont have to id rather not fit it (i removed the elbow for inspection) as its one less gasket to blow next time!
Cheers for the water flow info too
Location: southend on sea bruv under that fu##ing car bonnet
never use the gaskets on mine as its one more bloody thing to go wrong,,as long as both faces are clean and in good condition it should seal ok,,
#1 in Spelling Club
Steve, I think you will find that the surfaces aren't perfect enough not to run a Gasket. I'm pretty sure it will blow.
If you fit a new Genuine Nissan Gasket and make sure that all the studs/nuts are there and check their tightness from time-to-time, then the gasket should last fine.
Its only when the studs break or work loose than the Gasket is at risk of blowing.
i suppose everyone has there own methods,,mine never blew and i didnt have a gasket for 3 yrs and i ragged the cock off it, my mating surfaces were in good nick and i rubbed them flat with some wet and dry paper
DEYTUKURJERBS
I was thinking same as turbo7, giving them a good going over with some wet and dry, a smear of exhaust paste, some locking gunk on the nuts, all done up tight, and should be ok.
The elbow cant be removed without removing the turbo, and turbo cant be removed without removing the manifold, so you can see why im reluctant to fit a gasket again
The elbow gasket id rather not re-fit
The manifold to turbo gasket i just removed which was the catalist for this thread
thats exactly how my mates was, i would leave it without a gasket, even if the surfaces aint perfect, when the turbo becomes heated the metel expands anyway a creates a seal... none of my turbos have ever had em
#1 in Spelling Club
We ALWAYS run these with Gaskets.
It's an integral part of 200SX ownership to be honest, that the Turbo Gaskets will go from time-to-time.
We normally replace the whole set at once, which involves removing the Turbo. Once everything is on correctly and tight, then they don't normally cause a problem.
I can't help thinking it will blow, but thats your call.
DEYTUKURJERBS
Do you run water cooling to the turbos chris?
As i hacksawed them pipes off too
So maybe to continue the tradition i wont run gaskets either
Then again people say that welded diffs and cheapo rear tyres are deathtraps too and i run them
But they right
But they right
DEYTUKURJERBS
No But it will be whatever cooler i can pay the least for, anything from a 4x4 cossie one upwards
Ive not done the 1.5bar thing yet, tho have the inj's off my GTR i can use.
On standard T25 as.. (A)- I dont want to spend any money. And (B) outright power dont matter really, just want no lag and a big a big dollop of midrange wheelspinny torque.
Maybe i shall remove the pipe to the actuator
Ask me a question!
Yes basicaly mate.
I use the manifold to housing gasket on most of the Turbo's i build but both items are cleaned and blasted to make sure i have no trouble in the close future as eventualy every gasket or seal of some kind will fail due to wear and fatigue etc..
On most new Turbo's i supply i always include the gasket, its then upto the owner/customer to choose if they wish to use it.
50 / 50 call i spose, but why make a gasket if it dont work?
Regards
Regards
Escortdriver1
05-08-2015 12:45 PM
Escortdriver1
31-07-2015 02:36 PM
