General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
You shouldn't lower any Cossie too much, as it spoils the handling, especially a 4x4, which also has problems with popping the from drive shafts out if lowered excessively. What will you use the car for? If just road use, the Chasis Dynamic ones are okay 25mm lower or standard ride height for around £100. Or if you have Koni's, I can supply you with some specially wound LEDA springs designed for these dampers. But they are quite a bit more expensive at £160 delivered.
All the Eibach equipped Cossies I have seen (especially Sapphires) seem way to low at the back, so given that reason, I wouldn't recommend them. Seems bizarre, as they normally get it right...
