crank position sensor.. what does it do.....
bugger.
you could not up a mock light tester, using a sidelight bulb or something.
12v to one side of the bulb and then a wire from the other side to pin 1 on the fuel injector plug.
not the best method in the world, but one its cheap and two you should have all the necessary bits in your garage
yeah, guess so pal.
+ve feed for the bulb is the bottom yes? earth (inj) to the side?
whats pin 1 on the injector? as you are looking at the clip withthe release clip on top
left or right?
left or right?
Originally Posted by Dean Saff
A noid light would be cheap and easy
Originally Posted by GARETH T
if you havent sorted it dave,, want me too come down next weekend?
cheers though, the offer is appreciated i think its all sorted now anyway... i removed and cleaned the cam sensor..
alls running smoothly!
mike elsome
Sep 14, 2015 04:08 PM
