Question about valves?
Old Oct 20, 2005 | 10:21 AM
Greef's Avatar
Greef
Default Question about valves?
hi all
if you suspected a valve problem.. but checked the compression on all 4 cylinders (cosworth engine) and all 4 readings were identical and at 9 bar (low comp engine) would this deduce that all valves would appear to be ok and not bent?
thanks
Old Oct 20, 2005 | 10:27 AM
Greef's Avatar
Greef
oh dear, i seem to have 'newbie' itis
Old Oct 20, 2005 | 10:42 AM
apples24's Avatar
apples24
was that a hottest or cold, i believe i done a cold a long time ago AND SHOWED 8 BAR IN EACH THAT TURNED OUT TO BE FINE
Old Oct 20, 2005 | 10:44 AM
Greef's Avatar
Greef
warm test apples...
thing is , timing deffo went out on the belt.. im concerned about valve damage..
pistons have valve cut outs, but i did a comp test and all pots were the same
i re timed the car... started her up and all was fine.. but then she spluttered and cut out and now wont start.. about to check compression again.. but what if all readings are fine?
Old Oct 20, 2005 | 10:47 AM
apples24's Avatar
apples24
have to admit ive never eard f a cosie not damadge valves in similar circumstances a matter of fault diagnosis im affraid, but id be well happy if comp test is still good atleast the big bills are outs the way
Old Oct 20, 2005 | 10:54 AM
Greef's Avatar
Greef
hmmm, off to do another comp test now..
any one else any ideas?
Old Oct 20, 2005 | 11:03 AM
leakdown test would be better than a compression test, but if its reading at 9bar on all of them it sounsd like you got away with it.
you still may have cracked the guides etc though, i would take the head off and remove the valves as a matter of good practice to check.
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
richierich1986
Sep 18, 2015 03:29 PM
