missfire/backfire
Old Oct 14, 2005 | 05:21 PM
DaveEscos's Avatar
DaveEscos
Default missfire/backfire
just been for a test drive.. all seems ok.. no leaks... brakes spot on but....
massive backfire when at about i guess 4000 rpm
any reason why? what would cause this? incase ive overlooked aything?
wont be plugs, leads or dizzy as its all new
been dyno mapped so not a timing issue..
its getting fuel
cheers
Dave
Old Oct 14, 2005 | 05:25 PM
dave cos4x4's Avatar
dave cos4x4
is the fuel set at the right pressure.
Old Oct 14, 2005 | 05:33 PM
GARETH T's Avatar
GARETH T
map sensor pluged in?
Old Oct 14, 2005 | 05:34 PM
Graceland's Avatar
Graceland
Team HOTHOT!
phase sensor gap and crank sensor gap
Old Oct 14, 2005 | 05:47 PM
Dave i suspect you are hitting a limiter as you have a problem that the ECU doesnt like.....P8 with the lastest version software does this ..obviously all you sensors are working as your moniter will tell you that...is it lamda controlled if so make sure that working also check you are not overboosting..
Old Oct 14, 2005 | 05:56 PM
DaveEscos's Avatar
DaveEscos
fuel pressure is fine, just been set by harvey
map is plugged in
crank and phase should be ok.. had a look.. no probs there
Interesting re: the P8 Phil.. it is indeed like im hitting a limiter. What would be the cure though? and surely it would have done this on the dyno?
not running lambda control either
Old Oct 14, 2005 | 05:58 PM
dave cos4x4
Bad earth anywhere.
Old Oct 14, 2005 | 06:01 PM
DaveEscos's Avatar
DaveEscos
nope dave, doubt this would cause this brick wall backfire though
solid earth to the chassis
Well the ECU is goin into limp mode....
Turn the boost down to say 10psi and see if it still does it.
Old Oct 14, 2005 | 06:05 PM
DaveEscos's Avatar
DaveEscos
i have the air injectors unplugged.. im not running any boost lol!
Old Oct 14, 2005 | 06:07 PM
Sticky.'s Avatar
Sticky.
Sounds like the giggle pins are fooked Dave
Did the stickers turn up?
Old Oct 14, 2005 | 06:08 PM
DaveEscos's Avatar
DaveEscos
pmsl... no paul, not yet mate
Old Oct 14, 2005 | 06:09 PM
SPADGE's Avatar
SPADGE
Re-check the crank sensor gap Dave as they are easily knocked when fitting the engine! Should be around .8mm
Old Oct 14, 2005 | 06:12 PM
...well then as Spadge check ALL gaps
Old Oct 14, 2005 | 06:16 PM
DaveEscos's Avatar
DaveEscos
vat a pain in ze ass!
Old Oct 14, 2005 | 06:36 PM
Dave just thought connect the air injectors the ECU might think it got a fault if they arnt connected!
Old Oct 14, 2005 | 06:39 PM
DaveEscos's Avatar
DaveEscos
naah, tried that phil
vat a cooont
Old Oct 14, 2005 | 06:55 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Will be CPS with those symptoms . If your Pectel monitor was hooked up, you'd know instantly .
Old Oct 14, 2005 | 06:58 PM
Stu @ M Developments's Avatar
PassionFords Creator
Unplugging them gives maximm boost BTW
Old Oct 14, 2005 | 07:02 PM
DaveEscos's Avatar
DaveEscos
well thats another prob then LOL
so phase sensor gapped wrong then? is the general concencus
stu??
Old Oct 14, 2005 | 07:04 PM
SPADGE's Avatar
SPADGE
stu??
Nope the crank sensor not the phase sensor Dave!
Old Oct 14, 2005 | 07:05 PM
DaveEscos's Avatar
DaveEscos
sorry... typo!!
Old Oct 15, 2005 | 01:36 AM
DaveEscos's Avatar
DaveEscos
boiiiing... for more opinions
Old Oct 15, 2005 | 08:07 AM
justin.e's Avatar
justin.e
doesn't disconnecting the air to airs give unlimited boost!!!
Old Oct 15, 2005 | 08:24 AM
Unplugging them gives maximum boost BTW
Get with the program Justin
Old Oct 15, 2005 | 09:19 AM
justin.e's Avatar
justin.e
read down to where Dave said he had the air2airs unplugged
Old Oct 15, 2005 | 10:03 AM
Damo V's Avatar
Damo V
Dave have you looped the actuator and compressor housing together?
Old Oct 15, 2005 | 10:07 AM
DaveEscos's Avatar
DaveEscos
nope... reckon this is why? maybee an overboost limiter in the chip whilst we're running in?
Old Oct 15, 2005 | 10:18 AM
Damo V's Avatar
Damo V
Dont think the chip jhas a running in map... but could be overboost limiter as per stus suggestion of max boost,
Just unscrew the fittings from Air to Air then screw them together, this is what I had
Old Oct 15, 2005 | 10:22 AM
With the greatest of respect, maybe you should pay a pro to get her running properly Dave. Looking at your resto thread, youve got 10s of Ł000s on that setup now and you could EASILY have run 50+psi the way you disconnected those air injectors. Not to mention the 6000rpm cold starts with your ALS you mentioned elsewhere
Like i say, not a dig, maybe just time to let a pro finish what looks to be a properly decent specced escort.
DaveEscos's Avatar
DaveEscos
yeah, would make sense.. but we run about 28 psi.. i never got near that amount of boost on my 'test' drive
Old Oct 15, 2005 | 10:25 AM
DaveEscos's Avatar
DaveEscos
stu.. point taken, but ive got this far.. im not as mechanically stupid as i make myself out to be on here i havent run over 10 psi let alone 50 and slight exageration on the rpm.. still shes nearly there... once ive nailed down this backfire... roll on the chore of running in!
Old Oct 15, 2005 | 10:26 AM
I can tell your not totally Inept pal, just friendly advise, nothing more.
Old Oct 15, 2005 | 10:34 AM
DaveEscos's Avatar
DaveEscos
i know mate
Old Oct 15, 2005 | 10:38 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Take it to a pro even if you think you are capable of the work!
As Stu said you have spent X amount of money to get what you have and now risking it by guessing at this and that. IMO!
Old Oct 15, 2005 | 06:19 PM
DaveEscos's Avatar
DaveEscos
just an update.. replumbed the actuator and compressor..
no backfire... 0.5 bar held
fast as fook
brink on the running in!
Old Oct 15, 2005 | 06:22 PM
Damo V's Avatar
Damo V
Feel unusually quick at such low boost for some strange reason dont they lol... I reckon its because they havent been driven for so long and my van etc are just SLOW
lisa 23
Jan 25, 2011 12:37 PM
kevb1979
Mar 20, 2009 10:16 AM
