Domestic Electricians.........Advice please :-)
I have had an extension built (just the shell), and would like to know what is the score with the wiring.
I am capable of doing it myself (have actually routed it all in the loft prior to fitting loft insulation), leaving just the wire hanging out of all the sockets, but realise the regs changed as from this year.
So will i have to pay somebody to come and connect it up and certify it???
Can i connect it up, and get it checked to get certified???
or do i have any other options???
I was told by the builder that a householder is permitted to make extensions to existing circuits???
Is this true, if so, could i get away with connecting the new extension into the existing ring and lighting circuits???
Hope someone can help......
Team HOTHOT!
you could take a radial spur off the existing ring circuit, altho doing this would be easiest, it would be better to break the ring at a socket close to the extension and extend the ring circuit.
for the lighting circuit, you can take a spur off the existing downstairs lighting circuit with no problems providing the correct cable is used (1mm for 16amp lighting circuit and 2.5mm for 32 amp socket/outlet circuit)
Originally Posted by Graceland
you could take a radial spur off the existing ring circuit, ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Best to continue the ring...
I am unsure of the legislation of DIY now. I think it is becoming like gas fitting..needing to be corgi registered...
I would do it myself and get it checked off personally...
You can only put a 10amp max fuse/breaker in for a lighting circuit and i would use 1.5mm not 1mm. Only pennies difference pricewise. Any other probs, just ask mate.
Thanks VERY much for the replies
Just out of curiosity.....what does the inspection involve for Part P Cert.???
Will i be able to wire the complete circuit, or will i have to leave parts unconnected to be inspected inside i.e. ceiling roses, light switches etc.
Thanks again, you fella's on here always come up trumps
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
lardypants
25-04-2008 05:05 PM
Christian and Beccy
05-04-2005 01:13 PM
