Rear Disk Conversion, MK4 RS Turbo
As my new engine will be ready soon i thought it would be a good time to upgrade my brakes, the ABS pumps are comming out completly! 2wd Cosworth setup on the front and 2wd Rear Disk conversion on the rear,
With regards to the rear disk setup does anyone know where i can get the caliper brackets and tell me what else i need apart from rs2000 brake cable, 2x 2wd cosworth calipers, pads n disks?
Also where is the best (cheapest!) place to buy The GRS intercoolers for the Escort RS Turbo's?
Hi mate, done a cossie rear disc conversion on mine, got the kit from Brom @ Zoo
www.zoomotorsport.co.uk
Failing that 'richm' can probably sort you the brackets if that is all you need?
I notice you are from Suffolk, where abouts?
ok mate thanks ile check that link out, i may get the calipers from e-bay, so i think i will only need the brackets!
From Ipswich mate, u near by?
ok sorted out the rear disk conversion, thanks 'adamS2RST'
Now anyone know where i can order a GRS front mount intercooler from?
Drop Graham @ GRS an e-mail direct!!
graham@grsmotorsport.co.uk and have a look at the website www.grsmotorsport.co.uk
Matt Baxter
16-09-2015 08:30 PM
