how to use a pf09 TPS on a 2wd L6 ECU ??
As above, can I just switch around the two outer wires in the plug of the TPS and use the new pf09 TPS (mind you it's an L6 ECU 2wd saff).
Cheers Kennert
Cheers Kennert
Re: how to use a pf09 TPS on a 2wd L6 ECU ??
Cheers Kennert
Cheers Kennert
Testing the future
yeah but what engine loom do you have? 2wd or 4x4?
if you started with a 4x4 loom with the pf09 tps and you are now wanting to change to a L6 ecu for some reason, you'll need the pf01 tps and you'll need to swap the outer wires around.
if you have the 2wd loom, you'll still need the pf01 tps
DixieTheKid
11
06-06-2020 11:20 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
DixieTheKid
14-09-2015 09:04 PM
