HOW CAN I TELL IF I GOT LOW COMP PISTON`S OR NOT???
Old 04-07-2004, 09:47 PM
DOO
DOO's Avatar
Default HOW CAN I TELL IF I GOT LOW COMP PISTON`S OR NOT???
I was told by the chap i bought the car off that it had low compression piston fitted when it had a full rebuild.
How can i tell do a compression test or not ??
Old 04-07-2004, 09:48 PM
cossie1
cossie1's Avatar
afaik the only real way you can tell is by removing the head. altho I could be and probably am wrong
Old 04-07-2004, 09:55 PM
Glenn5
Glenn5's Avatar
Do a compression test m8 the figures will reveal what you have m8
Old 04-07-2004, 09:56 PM
SPADGE
SPADGE's Avatar
Doing a comp test will only tell you what the comp is and not the ratio!
The head needs to come off i do believe for anything else!
Old 04-07-2004, 09:57 PM
Karl
Norris Motorsport
Karl's Avatar
A compression test will reveal nothing in terms of identifying compression ratio.
The only way to verify if you have modified pistons is to remove the head and burette the piston crowns for volume.
Old 04-07-2004, 10:07 PM
DOO
DOO's Avatar
I think i leave it at stage 3 then for now.Only done 5000 miles since rebuild.Can`t be fooked to take the head off to find out
Cheers for the info lads anyway
Old 04-07-2004, 10:09 PM
AndyRST
AndyRST's Avatar
Tony, why dont you phone bluesprint motorsport. Im sure if you give them the car details and reg etc they will have a record of it. I know the previous owner was a little fussy when it came to rebuilding that engine Im sure he didnt do things by half
Old 04-07-2004, 10:11 PM
GARETH T
GARETH T's Avatar
anyone ever tried to do it thought the shark plug hole? even though it would be tricky
Old 04-07-2004, 10:14 PM
James
James's Avatar
It'd be difficult to get out whatever you put in then though.. ?
Old 04-07-2004, 10:16 PM
Karl
Norris Motorsport
Karl's Avatar
No can do gareth.
Piston rings can leak fluid giving inaccurate results.
I can do it this way if its a dummy build whereby I have filled the top ring area with grease to prevent fluid leakage. However its easier to simply burette all volumes rather than a dummy build just to measure C.R.
Hence on an engine thats in car its a no go.
Old 04-07-2004, 10:18 PM
DOO
DOO's Avatar
The only prob mate it was a cash job no invoice .I spoke to joe @ BLUESPRINT But he can remember the car and rebuilding it but not a 100% sure what work was done on it.
He did tell me the previous owner was fussy as fook though.
As i do trust the guy i bought it off was telling the truth i just wanted to be 100%.
Look like i may have to take the head off
Old 04-07-2004, 10:25 PM
AndyRST
AndyRST's Avatar
From memory the story goes something like this: They rebuilt the engine and before it was even run in the previous owner took it back to them and made them rebuild it again because he was unhappy about something minor thing with it
So yeah i heard he was a little fussy
Old 04-07-2004, 10:28 PM
Glenn5
Glenn5's Avatar
You could still do a comp test 2 see what the figures are if there all the same across all cyls and are low or high will help denote health of engine and will help explain whether low comp or std it wont give a comp ratio but will help
Old 04-07-2004, 10:31 PM
RSrussell
RSrussell's Avatar
what does buretting involve? I know what it does and heard the term use for ages but never actually know whats involved
Old 04-07-2004, 10:33 PM
Karl
Norris Motorsport
Karl's Avatar
Glenn5
NO it wont determine whether its std or low comp in any way!!!
Old 04-07-2004, 10:36 PM
DOO
DOO's Avatar
He did say he had to get the piston`s from germany.But that don`t mean anything to me
Old 04-07-2004, 10:38 PM
GARETH T
GARETH T's Avatar
Karl,
i was thinking baout the rings leaking!
Glenn5,
you gotta think about what effects the compression test, cam timing, cam choose being just two
Old 04-07-2004, 10:42 PM
smartrs
smartrs's Avatar
sorry to jump on your post but its kinda related , would anyone in the know say thease are low comp pistons ?? as i was told by the last owner that they are but am not sure ??
Old 04-07-2004, 10:45 PM
Glenn5
Glenn5's Avatar
SAD V .SAD
Old 04-07-2004, 10:47 PM
RSrussell
RSrussell's Avatar
Originally Posted by Glenn5
SAD V .SAD
wtf
Old 04-07-2004, 10:49 PM
Karl
Norris Motorsport
Karl's Avatar
smartrs, they look like std 4X4 pistons that have had valve cutouts machined into them, but I can't say for 100%!
Old 04-07-2004, 10:50 PM
GARETH T
GARETH T's Avatar
Glenn5,
wrong v wrong
Old 04-07-2004, 10:51 PM
smartrs
smartrs's Avatar
thanks karl thats all i need to know i hate having a enging that i dont really know the spec of , all i know is that it needs a set up and hopefully some one will be able to shead some light to the spec and what it caperble of ?
Old 04-07-2004, 10:53 PM
Glenn5
Glenn5's Avatar
WTF is a compression test 4 then if not 2 determine whether you have high or low comp on each cylinder.
Fudgey
Baby Cheesus
Fudgey's Avatar
only way to tell is to remove head
Old 04-07-2004, 10:57 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
DOO= Does it matter? You can go well past stg3 on std comp anyhow if live mapped, and TBH if u was going past stg3 youd idealy wana whip the head off to fit a decent gasket anyhow.
Old 04-07-2004, 10:58 PM
bob s2zvh
bob s2zvh's Avatar
how can you tell with the head off? i'm away to buy a low comp bottom end 2! had a quick look at it a few weeks ago and the pistons were dished! how deep should the dish be? or would the pistons just sit lwoer from the top?
Old 04-07-2004, 10:59 PM
Karl
Norris Motorsport
Karl's Avatar
Glenn5, I'm affraid your attitude is pretty poor!!
A compression test is used to test for leaking/bent valves or damaged/cracked piston rings. It can give an indication of general engine health IF you know the compression readings when the engine was new.
It is a very crude test simply to help identify if the engine has any obvious internal faults which would then require stripping to investigate.
Old 04-07-2004, 11:02 PM
Glenn5
Glenn5's Avatar
Default Re: HOW CAN I TELL IF I GOT LOW COMP PISTON`S OR NOT???
If you want ratio's take the head off. If you just want to know whether its High,Low or standard compression then do a compression test.
Simple really.
Old 04-07-2004, 11:08 PM
Karl
Norris Motorsport
Karl's Avatar
Glenn5,
You really don't get this do you. You're either stupid or have'nt read what I wrote above.
A compression test does NOT tell you whether your engine is high or low comp.
If you can't accept this I will give you an example that will help explain why it's of no use.
As I've said its a crude test to help identify IF a problem exists in the engine. The results do not indicate the C.R.
Old 04-07-2004, 11:12 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
low comp pistons are dished, only way to tell is to take off head
Old 04-07-2004, 11:13 PM
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
Karl is of course absolutely correct Glenn M8
Old 04-07-2004, 11:14 PM
Glenn5
Glenn5's Avatar
Simple really.
Like i said above if you want ratio's take the head off.
The question wasn't how do i determine ratio's just the compression.
Is anybody on this post to help or are we here just to bitch at each other?????
Old 04-07-2004, 11:18 PM
Karl
Norris Motorsport
Karl's Avatar
Glenn5,
Don't get all arsey because you're wrong. We are'nt all born knowing what we know! It's a learning curve for all of us including me and stu!!
Old 04-07-2004, 11:19 PM
Administrator
Glenn.
If you do a copmpression test and its low at say 120PSI. How will that tell you its a low comp set of pistons?
How do you know the valve's arent leaking or the piston rings not worn? Maybe even the followers are knackered and causing a low reading.
Old 04-07-2004, 11:20 PM
Administrator
Its been a while, but tonightr ive learnt that after only 5bottles of beer, i cant type properly... quality!!
James
James's Avatar
Glenn, I think you'll find he wants to know if he has low compression pistons or not, meaning a low compressin ratio as opposed to how much actual compression there is in there.
Old 04-07-2004, 11:21 PM
Karl
Norris Motorsport
Karl's Avatar
Not to mention stu the cam timing could be well out from factory, due to variances in manufacture, head height, and even the odd case where people have got the cam a tooth out!! lol
Old 04-07-2004, 11:26 PM
Administrator
Karl,
odd case
Whats odd aboout it? I find it more a "Normal" ccase.. roflol
DOO
DOO's Avatar
Originally Posted by Stu @ M Developments
Glenn.
Stu not geting into this argeument i may be wrong but the engines only done 5000 miles since rebiuld and running fine no knocks a rattles.
so i don`t think anything would be wrong.
so is it worth doing a comp test or not
Quick Reply: HOW CAN I TELL IF I GOT LOW COMP PISTON`S OR NOT???
