Rs Turbo ECU's
Rs Turbo ECU's
Lads,
I have a list for the engine ECU's....
S1 = Blue - Red - Blue ~ No knock sensor
S2 = pre 1987, Blue - Red - White ~ No knock sensor
S2 = 1987 Onwards, Blue - Red - Black ~ With knock sensor
S2 = 1990 Onwards, Hearts & Diamonds ~ With knock sensor
Which i belive to be correct, would anyone have the list for the fuel ECU's?
The one i have has a blue label and i've seen them with green labels too.
Curious what go with what?
Knock sensor was added to later cars, but its prone to giving problems. It's supossed to retard the ignition if detonation is detected, but it's mounted in a stupid place, and tends to alter the igntion depending on what colur boxers ur wearing, and the postion of the stars.
The loom is different for the fuel ecu, in the way the TPS works.
To modify the loom, you need to earth the TPS through the ECU, as on an s2 it earths to the body. I've done this on mine, as it totally removes the fuel rev limit - the omex soley controlls the rev limit.
Super Moderator
rick could you expand as even I don't understand what you are saying lol
You need to be more specific with the fuel box you are using and the wiring mod .
series 1 tps is live switching series 2 is earth switching
series one fuel box does not have a rev limiter series 2 does
big_Rad
15-09-2017 09:36 AM
Matt Baxter
16-09-2015 08:30 PM
