Engine mount question???
Old Oct 1, 2005 | 08:42 AM
Sticky.'s Avatar
Sticky.
Default Engine mount question???
How can you test to see if a engine mount has gone?
I keep getting a clunking noise coming from the right hand side, ive changed all the tca's with new ones, new bushes, new steering arms etc & the clunk is still there. The only thing i aint checked yet is the Koni & the top mount.
The clunk only happens when reversing on left lock or when you brakes hard, and sometime gives a slight clunk when going over a bump.
Any help would be appricated as i m running out of places to look now
Old Oct 1, 2005 | 09:23 AM
escortrsmatt's Avatar
escortrsmatt
have you checked your cv joints?
Old Oct 1, 2005 | 09:36 AM
Sticky.'s Avatar
Sticky.
Stupid question..how do cv joints?
Old Oct 1, 2005 | 09:38 AM
Graceland's Avatar
Graceland
Team HOTHOT!
matt - his car is 2wd not 4wd.
stickypoohs - the engine mounts on your car are fluid filled, they leak when they split, but that doesnt mean to say a nackered mount is garanteed to leak as they can be bolloxed and not leak.
also is your exhaust catching the bell housing on the gearbox.
Ginge !'s Avatar
Ginge !
just finding my feet
paul cv joints aint on your car
are you sure the zorst aint knocking, i had a knock on my cossie and it was my exhaust
Old Oct 1, 2005 | 09:42 AM
escortrsmatt
my bad
Old Oct 1, 2005 | 09:57 AM
Graceland's Avatar
Graceland
Team HOTHOT!
in your ass
Stickypoos - i'll have a look and listen when you get this gauge from me m8y
Old Oct 1, 2005 | 11:29 AM
Sticky.'s Avatar
Sticky.
im just to blame aswell i read the answer wrong
Its defo not the exhaust hitting the bell housing. Ive asked loads of peeps & they have said either
Engine Mount
Top Mount
Pads shifting in the caliper
Ainti Roll lose
Cross member lose
Im going to check all these again soon as the rain goes off.
Old Oct 1, 2005 | 11:32 AM
Graceland's Avatar
Graceland
Team HOTHOT!
my pads shift in the calipers - they don't knock tho, they rattle
Old Oct 1, 2005 | 11:40 AM
Sticky.'s Avatar
Sticky.
Thats what i thought mate, i changed the TCA's last night and checked all the calipers & they were fine.
Old Oct 1, 2005 | 11:41 AM
Graceland's Avatar
Graceland
Team HOTHOT!
d'oh - well when you come over for this boost gauge we'll have a little check and see what we can see
my money is on one of the dampers been faulty tho
Old Oct 1, 2005 | 09:17 PM
CosKev3's Avatar
CosKev3
Trolley jack under the sump is the easiest test m8
Jack the engine up slowly and see if the mounts come apart
I know its a big prob on the 4x4 cosworths,mine looked ok on my 4x4 looking down at them as soon as I jacked it up a bit they came apart totally
Old Oct 1, 2005 | 09:20 PM
CosKev3's Avatar
CosKev3
WTF?????
Fluid filled mounts????Tell us more m8
Got a 2wd mount here,just a big lump of solid rubber by the look of it
Old Oct 1, 2005 | 10:49 PM
Graceland's Avatar
Graceland
Team HOTHOT!
might be different on the 2wd cossie, but all the 2wd sierra mounts i've seen are like a liquid rubber inside a rubber case
Old Oct 2, 2005 | 03:50 PM
Damo V's Avatar
Damo V
suspension legs off, take them apart, one of the top spring cups will prob be broken.. servicable item lol
SmudgerByName
52
Jul 28, 2016 06:14 PM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
lockie
Jul 31, 2015 10:03 PM
