holding boost Q
holding boost Q
what should a /34 actuator hold if adjusted right coz i cant seem to hold any more than 1.5 bar but will over boost but will not hold any more than just 1.5 i ve put a bleed valve on it does the same thing i can make it over boost to 2 bar but goes strate back to 1.5
Norris Motorsport
A T34 with 0.48 exhaust housing and non cut back turbine wheel will only manage to hold 1.5 bar higher in the revs on a good cosworth engine.
This is down to increasing back pressure due to the restrictive turbine housing and wheel and the fact the engine consumes more air than the turbo can supply to give any more top end boost than 1.5 bar.
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
