MGF, common faults?
Old 21-09-2005, 03:47 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Check for dried poo/cum mix accidently smeared on various places due to the last last likely owners sexual activites with his "life partner"
Old 21-09-2005, 03:57 PM
4x4 ste
4x4 ste's Avatar
Yep head gasket and water leaks from my mates experience
and not that easy to work on with the engine at the back
personally wouldnt bother but each to there own
Old 21-09-2005, 04:26 PM
morcheen
morcheen's Avatar
Post subject: MGF, common faults?
the whole thing
Old 21-09-2005, 05:43 PM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
AFPMSL @ Steve. Its how you tell 'em.
MGF, LEAVE IT ALONE!!
Seriously.
Old 21-09-2005, 06:52 PM
Oranoco
Oranoco's Avatar
Well the MG/Rover badge is a big fuck up to start with. MX5 has to be the better option if you're in the market for a girlie hairdresser type car
Old 21-09-2005, 07:15 PM
RONNIE AMIS
RONNIE AMIS's Avatar
the k series engine come with plastic dowels between the head and block and when they gey old they crumble and the head moves. thats what makes the gasket go.if its been replaced before the new gaskets come with metal dowels to stop that happening. the rear shock bottom bushes normally fall out after a while and the rear trailing arm bushes wear quite bad too. the rads normally rot on them too if she does get one tell her to get the vvc they come with half leather and some other extras and their faster hope that was enough help sorry if it dont make much sense didnt do very well in english
Old 21-09-2005, 08:11 PM
NUTS RuS
NUTS RuS's Avatar
I can do my head gasket in under 1 hour, its not a big job. But a recent change on one on a MGF took me nearly 6 hours
Whilst the idea of putting the engine in the back appeals to some, my shovel sized hands couldn't fit down most of the gaps
Look out for water pump problems, and as above bushes on the rear are prone to wear.
Emisions can go haywire if there is a sign of HGF so if its due for MOT it could fail.
Old 21-09-2005, 08:15 PM
phil4x4saph
phil4x4saph's Avatar
They're not THAT bad! Do all the usual checks and you should be ok.
Head gaskets apart - they're made of reasonably proven parts. Its basicaly a Metro based kit car made by Rover!
Usually driven by older women (no offence to yer mum!) and have an easy life.
Old 21-09-2005, 08:23 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
phils dissin' your mum matt, sayin she old and drives like a pussy, dont have that
Old 21-09-2005, 08:36 PM
EIL132
EIL132's Avatar
MGF's are cheap because they are that, shit Built quality is shocking, buy an MX5, even an older one
Old 21-09-2005, 08:37 PM
RONNIE AMIS
i've done so many i can get the head off in about an hour and half now i reckon i've done 20 their not that bad
Old 21-09-2005, 08:38 PM
L33 BYT
L33 BYT's Avatar
They leak like the titanic. They eat rear tyres. They dent if you touch them and all the nice atributes of a Rover K -Series engine eg head gaskets/oil leaks
Old 21-09-2005, 08:45 PM
Karlos
Karlos's Avatar
definatly. if u go 4 the older model mx 5 u can av it on classic car insurance 2
Old 21-09-2005, 08:47 PM
NUTS RuS
NUTS RuS's Avatar
And with the 1.8 lump in it you should easily see off my 200bhp as mine is only the ickle 1600 motor. RONNIE AMIS you must double jointed and have little hands
Old 21-09-2005, 08:58 PM
Dave McB
Dave McB's Avatar
yup, i know a car dealer and he tells me the hood leaks on em, so check the interior for wet carpets etc
Its a rover, head gaskets are awful.
Get onto www.whatcar.co.uk for spec n report
Old 21-09-2005, 11:16 PM
Lee_R21Turbo
Lee_R21Turbo's Avatar
I've heard that the MGF chassis is based on 2 Metro subframes...is this true??? If so I think I'd be givin it a miss if I were you!!!!!
Oh yeah & they leak ALOT - I know of one car that went back to the dealers 6 times & they still couldnt stop it pissing in!!!
Old 21-09-2005, 11:22 PM
Nothing wrong with MGF's
The people on this site are something else
Old 22-09-2005, 02:21 AM
philc
philc's Avatar
mate had a low milege vvc one, it spat a plug out, head gasket went on another occasion, the vvc unit was worse than a diesel and the wind noise was terrible, it also leaked through the window in serious rain., couldnt see shit out of the rear window, (lost 7k value in less than a year although thats not a bad thing if your buying)
heater was top notch though your mum will love one, cheap as chips, not bad to drive and you can pretend to be a hair stylists cum bucket if you choose to drive it
Old 22-09-2005, 07:29 AM
Paddy
Legend
Paddy's Avatar
The VVC engine is shite, avoid the MGF, ignore anyone that says "oh my mates had one and it was good", we've had quite a few and stopped bothering with them because they're nothing but fucking trouble.
If she wants a decent, relaible car with a removable roof, the later Honda CRX's are great value for money
Old 22-09-2005, 08:14 AM
djbolf
djbolf's Avatar
build your own out of a metro or two
Old 22-09-2005, 08:20 AM
It's Czech Mate
It's Czech Mate's Avatar
CRX Del Sol is a good shout paddy
Old 22-09-2005, 05:44 PM
Oranoco
Oranoco's Avatar
Escort Cabby?
Old 22-09-2005, 05:47 PM
Oranoco
Oranoco's Avatar
Just done a quick look on AutoTrader and found almost a whole page of 2000 registered MX5's for Ł6500. You should have no probs getting one. A few were garage sales as well
Old 22-09-2005, 05:51 PM
morcheen
morcheen's Avatar
stick to the bus pass,much cheaper and more reliable.
Old 22-09-2005, 07:25 PM
focusv8
focusv8's Avatar
MGF.......Two front Metro subframes joined together with baked bean cans (not even Heinz) .....then covered in plastercene.
Coolant transfer tubes from mid engine to radiator at the front, corrode, causes coolant loss, pops head gasket, replace tubes with stainless ones before they go, and fit modified type head gasket.
When refilling the coolant, getting air out of the system involves jacking the car up at an angle and filling slowly, otherwise you will be changing the head gasket the next day.
Subframe mounts allow the subframes to float about, so when hitting potholes it will jump across the road. Solid mounts are available.
Dont try and work on the engine without removing the soft-top completely, the rear window WILL break.
Old 22-09-2005, 07:44 PM
roybacer
roybacer's Avatar
thought about a 306???
1999 T Reg PEUGEOT 306 2.02 Doors, Manual, Cabriolet, Petrol, 43,724 miles, Orange, MOT-05-2006, 2 Owners. ABS, Adjustable seats, Adjustable steering column/wheel, Alloy wheels, Driver airbag, Electric mirrors, Electric windows, Foglights, Head restraints, Immobiliser, Passenger airbag, Power assisted steering, Remote locking, Sports seats, CD Multichanger, Central locking, Cloth upholstery, Colour coding - Body, Full service history, Heated screen, Locking wheel nuts, Metallic paintwork, Radio, Radio/Cassette, Sideskirts, Sunblind, Sunroof, Wood/wood effect trim. Insurance Group:14, Convertable, CD Multichanger Ł6,590.
fall within your price range, fun to drive, fast enough for your mum , look good, reliable enough, hold there value well, and cheap parts/servicing
Old 23-09-2005, 09:48 PM
James
James's Avatar
I've worked on a few MGF's and think they're fine tbh. Yes head gaskets go, but they look alright, they go alright, they look good with the roof up & handle ok. It's not badly built either. Yes it uses Metro sub frames but it does the job who cares?
Personally i'd avoid the MX5 more than the MG they rust bad, cambelt is awkward, door handles are a shit idea.
306 cabbies are shite aswell, the roof leaks everywhere, the hydraulics on the roof is a very bad design, and expensive when it goes wrong, heater matrixs are a common fault & theres loads of chassis flex.
& if you consider the Saab 900 then don't thats awful aswell.
Old 23-09-2005, 10:21 PM
Katie
Katie's Avatar
Mx-5 ....my mum has a red one and can't even get a go in it she loves it so much..
Dear Matts mum: If you aren't fat (like Phils step mum who needed a shoe horn to get in hers ) buy one...never broken down, never had a problem with it
Old 23-09-2005, 10:40 PM
GrimmeRS2K
GrimmeRS2K's Avatar
a bloke i worked with brought one, done 6k, rings went, but his new engine done 2k now has been ok, dont know how long though till the headgasket goes
Old 23-09-2005, 10:47 PM
big russ
big russ's Avatar
MGF's are true shit.I'd rather have piles
Old 24-09-2005, 08:01 AM
AlexF
AlexF's Avatar
MX5... no way
Parts are unbelieveable expensive!
MGF aint that bad... much better handling that a mx5 too
Alex
tankybaby66
06-02-2016 02:24 PM
Neil Clark
21
01-10-2015 07:02 PM
DixieTheKid
14-09-2015 09:04 PM
hopper350
04-09-2015 12:53 AM
Quick Reply: MGF, common faults?
