is ABS needed on a 3-door?
before i flog my ABS sensors to dave just seeing if im gonna shoot myself in the foot by getting rid of them.
car will be about 350bhp when done, but is ABS really necessary??
cant really be bothered with the extra wiring and pipework etc
CUNT!
Location: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
Personally I would keep the ABS and use a switch to turn it on and off as you want. 99% of the time it's turned off on my car, not keen on ABS at all.
How have you been getting an MOT then Andy?
Thought that was a failure?
Or have you wired the ABS light up to the alternator light on the dash or something
Dan, i dont think that any car NEEDS to have ABS, but its a useful safety addition.
It is an MOT failure, on the 3dr however (as you know) there are two little amber LEDS for the ABS lights and they didn't notice this (and i didn't tell them ) if it was abig red light with "ABS" then i think it would be a different matter (and time to wire the ABS light to the oil pressure light or similar!)
Go speak to Renton, we ripped all the ABS set up and servo out of the 3 door and replaced it with a pedal bias box.
I'm sure he will let you have it all at a good rate. I would just give it to you if I could be bothered to sort it all out.... but I can't which is why I'm telling you to speak to him
cheers lee, looks like far too much effort.
rich, the shell i have is a b reg 1.6GL, with no abs so it wont have all that gubbins in there.
with regard to a bias pedal box, not only do they sound expensive but do they allow you to adjust front and rear biasing i take it?
similar to a bias valve that you can buy?
gees iim not too clued up on this
A bias pedal box has a separate master cylinder for front and rear brake setups. The cylinders are usually connected by a balance bar, which allows you to distribute the pedal effort between the two clyinders.
Mine:
Mine:
For a brand new super bling one like Lee's, fitted, with all the bulkhead mods, expect over Ł1k.
Mine was about half that, but the body already had the mods done.
Unless you're used to it, driving with a pedal box is a very "interesting" experience if you're only used to road stuff, as you've no servo.
Personally, I'd stick with the ABS, plumb everything in, and have the option to switch it off.
Testing the future
a base model without abs originally fitted will also require bulkhead mods to fit it, albeit quite minor. iirc, you will need a brake pedal from an abs model as well, as the end where it actuates the master cylinder may be different. can't remember properly, it was nearly 5 years ago when i done it.
Re: is ABS needed on a 3-door?
Two ABS topics on one day.. wow (another one in Escos forum).
It is only matter of you skill. If you can brake well you don't need it. If you don't or are scared you need it. I switc of or brake ABS on all cars I can. I hate it.
Testing the future
it's not a matter of if you can brake well - most people can, most of the time. it's those times of emergency when instinct takes over from driver training and you just press the pedal harder and harder. that's when you need abs.
a lot of people can do a complicated manouvre involving braking and turning to avoid something on a test track or in a rally when they have advanced warning of the obstacle (training or pace notes), but when it's completely unexpected (like a child running out in the road ) it becomes more difficult
It all goes back to skill at some point. I think 90% people from Subaru Club I know have ABS disconnected and all 3 Escos cars here I know have ABS broken or disconnected.
Maybe I am dangerous driver, but I simply cannot understand all this panic about locking-up. ABS has it's uses and I don't want to contradict that - usefull for those who don't have inclination or need to grow as drivers. That is what I think. I am really mad with EEC ragulation making ABS obligatory on new cars (as with nearly all new legislation connected to automobilism).
By the way - my Seicento has no ABS and shit tires, I drove in areas you know in Germany and I even braked from 180km/h on wet road and am still alive. Maybe just luck?
Azrael - unforunately most people aren't trained, and unless they race, they wouldn't be.
For the racing driver, in racing conditions, then of course ABS is not required, and braking is better without.
However, and as Dan will admit, he's no racing driver, AND he wants to use the car on the road.
I'd rather have the ABS, as with even the most experienced driver like Mike R for example, even he would have stopped faster with the ABS on, and not had the accident he did.
well i managed a FOOKIN ace manouver a few years ago in the missus old mk2 fez, pissing rain on a duel carrageway, a lorry stopped in 1 lane, and cars skidding everywhere, it also involved the entrance and exit of a petrol station forecourt
i locked up, as a car came skidding in front of me, turned, off the brake, up the forcourt and out the other side
proppa shit myslef
but thats not to say that the ABS on my cabby helped when i nudged a landrover up the arse
proppa shit myslef
It's personal matter and anyone can decide whatever he want's. But if somebody ask if he can drive his car without ABS the answer is always yes (only on some modern cars you need to inwest in some mods to do that).
My personal choice is that ABS is good for my mom bad for me And that is only answer I can give to such question.
rich, very true about me not being a race driver, but i do aim to take courses etc when the car is done so i can learn to drive it properly etc
)) The best way to do it !!! :-D
ABS is weight, and weight is enemy of performance
Testing the future
i agree that driver training is very important, but it's very rare for a driver to be better than an abs/esp system under all circumstances all of the time.
agreed that the 3 channel system on cossies is not the best, and the slow pulsing rate is also very bad, particularly on snow/ice.
Anyway - for many many years people could live without those, why not anymore? Safety is in drivers head anyway - you have to foresee road situations, be prepared at all times and so on. Panic braking schouldn't happen more then couple of times in your life as my instructor often says. IF it does it's your driving style not the brakes.
Testing the future
personally, like you, i would rather be in control of these things most of the time. but i would prefer to know that if my skills fail me, that there is something there to help me out. obviously if the abs system cuts in earlier than is physically possible by a moderately skilled driver, then it's not good enough.
you're right, but if that one time you need it and don't have it and you injure or kill someone you might feel differently.
I am surely nothingmore then moderately skilled, then all ABS systems so far are shit
Jack and the Beanstalk
09-08-2015 07:03 PM
