Help required - headlight ducts
#42
i used a trumpter for mine, I think i have to red Piper cross trumpets in my garage if you want i will ave a lookski foryou
however i know its gonna get shot down, but what about taking out the indicator bit next to the quad lights (might not be an inidactor as i seen some esc cos's with them blanked off, and assuming you dont use it that is
) and make a duct type thing out of fiberglass similar to the headlight ducts the RST boys use
or shall i get my coat,
#44
Gra,
They're sidelights on the Escort, and the good thing is that the Morrette outer light has a facility to move the sidelights to this.
I actually like that idea a lot
. I have a couple of spare ones, I'll see what can be done, as well as removing the inner lights
Milky / John,
Could you take some photos from inside the engine bay?
Milky / John,
#46
Mike - My Esc is with a new owner now.
But you cant see much anyway, you need to split the morettes to fit the ports, then secure it, I jus made a little L shaped bracket, and self tapped it into the morette back plate, if you take one out and av a look, all will become clear.
wowk
30-03-2021 07:49 PM
Steve Escos
01-10-2015 06:57 AM
