View Poll Results: Which intercooler style is best?
Voters: 7. You may not vote on this poll
Custom intercooler designs, which of these is best?
i have three 2wd cosworth intercoolers, im planning on making one big intercooler with the cores (same idea as the one from NMS) to use with my t34 zetec turbo at up to 2bar.
which of these below would be the best way to go about it for efficiency etc? will they all cool and flow the air at the same rate etc? ignore the inlet and outlet positions.
A - standard run of the mill intercooler style
B - having the 3 intercoolers in series
C - using half of the middle 2wd intercooler on the inlet side, half on the outlet
D - cut the cores in half and weld them up to allow air flow bottom to top
any views or input welcome
B & C will give you a higher pressure drop for the same surface area, so not as good as A. however, the end tank design in A is crucial to get even flow through the entire core, whereas it's not as important in C and less so in B
depends what ya want, b looks to have the most efficient cooling BUT are act's that bad ya need it ??
a looks to have the best flow but end caps need to be looked at tbh
c dont even make sence with the end caps unless ya gonna cap the middle of the center coooler
heres a silly idea btw, why not chop all 3 coolers in half and mount em like pro alloy( bottom to top) just a idea, that way ya really only need 2 and will ease fitting aswell as reduce install probs and water temps
b19bal, for intercooler C the centre of the middle intercooler core was going to have the end caps on the right hand side welded to it, so half would be used to flow one way (right to left) and the other half flow the other way (left to right)
good idea about cutting the cores and mounting them this way tho
A or D would be worth doing. UK seem to favour style A for IC's whereas in the US they go for IC's more like setup D.
B would pose a massive restriction, and I wouldnt even consider it.
C would be OK, but unless you actually needed both inlet and outlet on same side, I wouldnt bother with it.
d is like a pro alloy coooler but ya can make it shorter than a rs500 as its thicker as hes using a 3 2wd coolers thus allowing air to the rad but at the same time allows it to remain single pass to reduce presure drop
glad ya like me idea
i have allready done this using the 3 intercoolers and the rolling road shows it worked well as diagram A
would deffo recomend doing it alot better than the pace one i had before.
