Cosworth has us stumped
Location: Sudbury Suffolk, Drives: Octavia VRS & XR2i 1800 Zetec track car
Some may remember upon bringing it out of hibernation we had problems with a dodgy battery, the result of it being sat in the garage all winter causing running and cutting out problems – battery was replaced and seemed to be fine since.
The new battery unfortunately had run down a couple of times, but been fine after a quick charge (really must get a trickle charger) Saturday J spent most of the afternoon tinkering with the actuator and finally got it running great holding about 14psi – all the time starting it, taking for a quick blast then back to the garage to wind it up a bit more. We stopped at local Tesco to check tyre pressure and I was going to drive it home, it started then stalled a second later – then cranked and cranked and wouldn’t start (this happened beginning of the year too) the battery then died – put the batterY from the XR on and it started and ran fine.
Started and ran sweet as a nut on way to Trax doing 100 odd miles, holding boost at 15psi sitting at xxx mph at one point and sat in all that traffic getting in. Left Trax with no problems, stopped about 40 miles from Silverstone to top up the fuel (£1.02p a litre
) then pulling out of the slip road it died, cranked over and over and wouldn’t start – eventually started and got another 20 odd miles down the road, didn’t boost and didn’t drop the revs (I know they take a lot of power from the battery on full load, though the alternator is charging as battery showing 13.9v when running so still not convinced it a voltage problem? And revving it makes no difference it still dies, in fact you aren't able to rev it, it just cuts out completely) slowing down for some traffic and it cut out again for no reason. Luckily coasted to a layby, theres no hardshoulder on this part of the A14 so had to call recovery and get it trailered home – bastard started first time and drove up the ramps, also started once home and drove into the garage, and fired up perfectly the next morning.
So pretty sure it can’t be a battery fault, or fuel (its only stage one running standard 4x4 injectors, no1 plug slightly black but mainly smells slightly of oil) we going to check the ignition amplifier terminal and J got a couple other things he going to check, seems to be an intermitent problem which confuses me, seems a mystery why it seems to stall for no reason out of the blue
any suggestions anybody?
Z
Z
Crank sensor?
Had a similar problem on our Escort, would cut out about 3krpm and if it got past it again about 6krpm but would kick in again, the limiter worked though
but sometimes trying to start it would turn over and over and wouldn't fire, put a booster over the battery or another battery and fine again, already had new battery as well.
1 Post
crank sensor connector full of water and/or dried out ming, when its cranking and not firing , whip a plug out and check that you have a spark, chances are there isnt one.
I believe it had crank sensor fairly recently (well within a couple of years, don't hold me to that though) it doesn't go out in the wet, though perhaps condensation or something may have got it or simply worn - cheers something to check, bloody annoying as you can only check when it decides to break down and ATM it seems to be running fine until the next time it decides to cut out
just have to go round and round the block until it breaks again!
Z
Z
![](http://www.girlracer-forums.co.uk/images/smiles/thumb.gif)
next time it's playing up, try and read a fault code from the ecu
Z
But it doesn't work on chipped cars
Z
Originally Posted by Dave Henshall
i heard a romour that the tdc and phase sensors only lasted about 30K miles before they needed replacment anyway
Z
Following on from Stu's Tech topic about fuel pressure where voltage to the fuel pump was mentioned - J wondered if the fuel pump was dodgy causing the above problem (which is intermittent) so is it feasible that the wiring/voltage to the fuel pump is dodgy? (how do I test the voltage to the pump?)
Z
Z
When she cuts out, does the rev counter drop like a stone, as though your turned the ignition off?
Intermittent and then starts again after cool down period:
1st suspect is the Ignition Amplifier.
2nd suspect is the crank Sensor or wiring.
3rd is the Fuel pump relay.
just finding my feet
thats whatr mine was doing, changed the crank sensor and that never cured it so i removed the engine and bought a new one
bit extreme bit with all new sensors, engine, fuel pump and loom im hoping its solves it
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Adam Graham
06-09-2015 06:04 AM
