any mk4 escort rev counters use a negative pulse?
Old Sep 5, 2005 | 06:36 PM
mrviper's Avatar
mrviper
Default any mk4 escort rev counters use a negative pulse?
i went to connect my omex up to my s2 and the omex has a negative pulse but the rev counter needs a live
i know my s2 dials need a live pulse because i flicked a bit of wire conected to the green cable on the multiplug over a live and the needle moved up slightly but the omex 500 uses an earthed pulse to make the dials work
so are there any rev counters out there that will work with a negative pulse?
cheers! mr v
Old Sep 5, 2005 | 06:37 PM
Jim Galbally's Avatar
Jim Galbally
i thought they all used nagative pulses, cos it takes the feed from the -ve on the coil?
Old Sep 5, 2005 | 06:54 PM
mrviper's Avatar
mrviper
my mate just said what about efi xr3i guages?
Old Sep 5, 2005 | 09:23 PM
Damo V's Avatar
Damo V
think jim is right mate, just connect it up see what happens
Old Sep 5, 2005 | 09:32 PM
mrviper's Avatar
mrviper
oki koki
Old Sep 5, 2005 | 09:45 PM
Damo V's Avatar
Damo V
think you will find if you have a coilpack, it wont read properly though... afaik, a resistor helps with this though
Old Sep 5, 2005 | 09:48 PM
turbo7's Avatar
turbo7
From: southend on sea bruv under that fu##ing car bonnet
use the xr3i efi clocks like mr viper said
Old Sep 5, 2005 | 10:56 PM
mrviper's Avatar
mrviper
are thease clocks hard to get hold of?
and would somthing out of a bob std EFI orion work because im not shure if the speedo goes as high and the temp/fuel guages are the same
Old Sep 5, 2005 | 11:03 PM
turbo7's Avatar
turbo7
yeah the orion ones are the same as escorts and they should be easy to get hold of make sure the petrol and temp are the same as yours and the speedo is the same mate
Old Sep 5, 2005 | 11:25 PM
mrviper's Avatar
mrviper
nice one i shal have a rummage around the local scrap yard then
thanks for all your help people
Old Sep 6, 2005 | 09:04 AM
turbo7's Avatar
turbo7
no probs mate hope all goes well
cozzy jeff
Aug 31, 2015 04:14 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
ekjim
Aug 17, 2015 08:57 PM
cozzy jeff
Aug 14, 2015 05:46 PM
stevierob
Aug 11, 2015 09:08 PM
