does your pc run hot ???
Old Sep 4, 2005 | 10:38 PM
SS1's Avatar
SS1
Default does your pc run hot ???
got a £1 k upgrade bout 2 months back ..AWESOME SPECS
BUT FOOK ME IT THROWS OUT THE HEAT ..
its got 5 fans inside on m board gcard ..and stuff
room is like a oven ..after a while need all windows open
and also needs the side off the case ...builder of it said
COULD DUST BE A ISSUE with the side off
ie place it back on when not using it ???
Old Sep 4, 2005 | 10:40 PM
Adam Ash's Avatar
Adam Ash
Your not runing an Abit AI-7 motherboard and a pentium 4 Prescott processor are you by any chance?
Old Sep 4, 2005 | 10:41 PM
Jim Galbally's Avatar
Jim Galbally
if it needs the side of the case off, it's a shit case
proper cases are designed with internal airflow in mind, so removing the side will make it run hotter as it disrupts the all important airflow
mine's not all that high spec, but fook me does it run hot had to relocate the case, as it was stuffed in the corner n kept overheating. now its situated with good clearance and it runs ok
Adam Ash's Avatar
Adam Ash
cooling wont work properly with the side off either, and dust buildup increases the heat
Old Sep 4, 2005 | 10:47 PM
SS1's Avatar
SS1
Adam Ash not really sure its a duel bios mother board custom version
will have a look for the specs in a mo
Old Sep 4, 2005 | 10:53 PM
SS1's Avatar
SS1
Old Sep 4, 2005 | 11:00 PM
Adam Ash's Avatar
Adam Ash
how hot and how are you monitering temps m8?
Old Sep 4, 2005 | 11:07 PM
SS1's Avatar
SS1
just open a window
i think its ment to run that way tbh ...fans go up and down ..
kick in when intense usage downloading stuff and playing games
the builder said it muliy threads of someting like that
so it boosts the ram ..so its got 2 gigs ???
fook knows ..
but its a dream to use playing games ..
Old Sep 5, 2005 | 12:43 AM
SS1's Avatar
SS1
above was a specs list from battlefield 2 program..list specs
any user here got a program to tell wot its really doing
cheers
dombanks
Sep 21, 2015 08:38 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
Eigdoog
Sep 13, 2015 05:46 AM
StephTell
Sep 2, 2015 06:31 PM
