Motorised screen dvd player to fit saff cos
Wanted a bit of help any saff cos owners out there with a motorised screen fitted to the standard din hole where the origional stereo was?
What make and model and can u still get them dont mind which one but has to clear the overhang when screen out....
Thanx in advance
Si
Thanx in advance
Si
0-60 in 17 seconds (eek)
As far as I know, there isn't one that extends far enough, and even if there was, I'd be worried about hitting it with my fingers on fast gearchanges.
I've made a holdler that fits where the computer module and clock are, most have fitted them in the top air vents.
If you don't want to loose your vents, in a past conversation chip suggested putting the vents where the stereo normally goes, sounds like a good idea, but I haven't looked into the feasibility.
Here are a few pictures to give you an idea.
Trial fit before painting
can still see the top of the gauges (the useful bit)
Hope this helps
Hope this helps
Originally Posted by JC MOTORSPORT
i have fitted mone in the top vents where nyou normally put the gauges
then you can put the gauges where the radio goes
thanks jc
thanks jc
Hello mate, I just made a surround for mine to bring it forward so it would clear everything, still fits down the bottom and clears fine, just can't see the clock when it is up, viewing is still easy as most of the screens have adjustable tilt.
Soon a 6 Defi gauges ACT, boost, oil preasure, oil temperature, water temperarute and fuel Preasure, 3 up in the air ventilation and other 3 down of screen!!
mrmann
20-08-2015 11:24 PM
salsheikh
Alloy wheels and ICE for sale
30-07-2015 08:45 PM
