Power Engineering.................your views
Old Aug 23, 2005 | 07:57 PM
GUZZLER's Avatar
GUZZLER
Default Power Engineering.................your views
as above really, i dont want this to turn into a slagging off post, just want a bit of feedback of what people think of Power Engineering these days.
Old Aug 23, 2005 | 07:59 PM
aduz's Avatar
aduz
Default Re: Power Engineering.................your views
think they are more into jap stuff these days..i had some work done on one of my rs turb years ago and i wasnt impressed
Old Aug 23, 2005 | 08:03 PM
GUZZLER's Avatar
GUZZLER
there still into Fords, but they do have a lot customers with Jap cars aswell.
Old Aug 23, 2005 | 08:06 PM
Rippers's Avatar
Rippers
Monte Geek
Went twice back in the day when mervyn was there and he set my FRST up the bollocks, after he left had another setup which was terrible (fitted a charge cooler the boost needed turning up and where as before Mervyn adjusted my actuator rod the other dude wouldn't do it incase he burnt his hands and proceeded to make a bleed valve from a washer jet t-piece!)
This was about 4 years ago and whether they are any better I don't know??
Like everything its not always the company its people that work there.
Old Aug 23, 2005 | 08:10 PM
aduz's Avatar
aduz
yeah i remember merv
i had to drive 300miles home with a faulty chip
Old Aug 23, 2005 | 08:32 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Matt, used them for many years for servicing on my 4x4 cossie. Couldn't fault them really, car ran without any problems for 7 years (and still is), however, as the years went by, I felt as though they were less and less interested in my custom, and I kinda felt like I was wasting their time
Straw that broke the camel's back was last time I went after I rebuild my cyl. head. Car had a high idle, booked the car in for rolling road setup, chap there plugged some diagnostics thing in, said MAP or TPS. Changed the MAP sensor = no change. Looked at the TPS from across the workshop, said "oh, that's a 2wd TPS (on a 4x4)" and used a known working 2wd TPS, same problem.
Turned out (as I found out at home and thanks to PF), that the TPS was in fact a 4x4 one (wrong color though), and it was incorrectly adjusted. So I managed to fix the car myself.
I paid Ł95 to be told car had to be booked in for a full electrical check at a cost of min Ł200....
I wasn't impressed by my last visit. Rod convinced me that Sheady would in fact service my car (didn't think he would).
That's about it.
Hope it helps
Jim Galbally's Avatar
Jim Galbally
i had a bad experienc with them so wouldnt ever go back
Old Aug 23, 2005 | 09:24 PM
Cam's Avatar
Cam
I went there once with my 1st EsCos and didn't rate them. Wankers imo
Old Aug 23, 2005 | 09:25 PM
i know a few people that use them and have no problems. infact i need to take my S2 there soon to get set up.....well over due
Old Aug 23, 2005 | 09:28 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
Ive never heard bad things
Matt
Old Aug 23, 2005 | 10:28 PM
nigel b's Avatar
nigel b
i would say they are now has beens-trading on past glory to an extent
ive never used them as i use mark shead
Old Aug 23, 2005 | 10:36 PM
phil4x4saph's Avatar
phil4x4saph
I took my saph there with eratic running, and for a RR set up.
Almost imediatley they said they couldnt rolling road it cos the transfer box is a bit fooked (mostly rear drive) but diagnosed the running problem as the inlet gasket.
I waited around while they changed it, and while I thought the labour rate was bloody steep - I cant really fault the service.
Old Aug 23, 2005 | 10:57 PM
RichardPON's Avatar
RichardPON
Originally Posted by Cam
Wankers imo
No Cam, say what you really feel
Old Aug 23, 2005 | 11:20 PM
bud-weis's Avatar
bud-weis
Football Cwazy
Matt
read the above
Old Aug 23, 2005 | 11:25 PM
DanRSturbo's Avatar
DanRSturbo
I've never had any problems with my car, and it'll be going back there soon for another check up
Old Aug 23, 2005 | 11:46 PM
Physio's Avatar
Physio
They were ok back in the days of RST's but Mark Sheads the way forward no doubt
Old Aug 23, 2005 | 11:54 PM
Daveyraveygravy's Avatar
Daveyraveygravy
Heard lots of bad things about them, my advice go to Mark @ MAD
Old Aug 24, 2005 | 02:43 AM
philc's Avatar
philc
only had a r/r day theree with the interford lot, but you cant really go wrong with a 2 year old car!! so i cant comment on any sort of tech services but they semmed to be knowledgable and courtious but i am easily fooled
Old Aug 24, 2005 | 02:48 AM
simonc's Avatar
simonc
Used them once about 12 years ago ! 1st impressions stick, wouldn't ever bother going there again & wouldn't recommend them to anyone either.
Simon.
Old Aug 24, 2005 | 03:10 AM
Cam's Avatar
Cam
Wankers imo
I always do in fact timewasting wankers would be more accurate!
Old Aug 24, 2005 | 05:44 AM
Chris Holmes's Avatar
Chris Holmes
over the last 12 months i have spent most of my time there getting my car sorted. They never got sick of the sight of my car and believe me it caused them a few head aches. They sorted every little problem and I actually got to know Ian and Chris quite well, top blokes IMO. Show a general interest in your car and will do all they can to help.
Also run an excellent club rolling road day.
Old Aug 24, 2005 | 08:20 AM
Matt Lewis's Avatar
Matt Lewis
Matt
read the above
Until now!!!!!!!!!
Old Aug 24, 2005 | 09:07 AM
AndyBlackFRST's Avatar
AndyBlackFRST
Visited with a friend 3 years ago to have his new piper cam fitted and car setup.
The car seemed to run fine ... 2 days later the rocker came off in the head, when removing the rocker cover we discovered the 2 others were only finger tight
Old Aug 24, 2005 | 09:12 AM
Toe Knee's Avatar
Toe Knee
Wasnt impressed with the fact they missed out on a few serious faults when i took mine to get it set up. Told them i was having a bad miss off boost an sometimes became undrivable. Was checked over and the only fault they diagnosed was that the pump voltage was droping and needed re-wireing and stoped working on it, and it was leaning out on high boost.
After taking it away and talkin 2 a few ppl realised the miss/bad running was due to a split plenum gasket and after re-wireing the pump, i drove the car up to Stu (MSD) he found the fuel reg was fucked, the CPS was slightly out of position, 2 things that should have been found at Powers, which meant stu couldnt finish setting it up as it was leaning out in high boost.
Know a fair few ppl that have had no probs there so its not all bad, just my experiance of them.
Old Aug 24, 2005 | 09:13 AM
SassyRS's Avatar
SassyRS
Little Miss...
Nice to have a few different opinions, lets hope Matts presence can make that all change for the better
Old Aug 24, 2005 | 09:16 AM
Maria.'s Avatar
Maria.
I took my Evo and my Escort Cos there, and never had any problems. They went out of there way to help!
Old Aug 24, 2005 | 09:17 AM
Matt Lewis's Avatar
Matt Lewis
Im sure it will
Old Aug 24, 2005 | 09:18 AM
SassyRS's Avatar
SassyRS
Little Miss...
Old Aug 24, 2005 | 09:20 AM
Toe Knee's Avatar
Toe Knee
Being blonde, female and fit probably helped u a bit there.................
Old Aug 24, 2005 | 09:22 AM
Maria.'s Avatar
Maria.
shut it trappy!
Old Aug 24, 2005 | 09:26 AM
Quickie's Avatar
Quickie
went there yesterday for a set up the run was stopped as i had a few problems they gave me a list of things to do which i did when i got home,the car runs soooooo nice now i would use them again no problem.
They also sorted out mt mates RS that has never been set up before he was beaming all the way home.
Old Aug 24, 2005 | 09:44 AM
boXXer's Avatar
boXXer
GASH!
i went there for a rolling road run a few months ago with a couple of mates, (my 3dr, mk2 golf with "home" ignition advance setup , and a polish astra turbo, and polish puma, he might remember us!) when my cossie was standard, and i think it was chris (the tall one???) was a really nice bloke and seemed very interested in our cars. Didnt have any technical work done so cant comment on that.
Old Aug 24, 2005 | 09:57 AM
PKA's Avatar
PKA
I have had my cars at PE for Power Runs and Servicing never had a problem down there. Also they have built a few Focus turbos (6 IIRC) that had issues but they sorted them out everytime, Customer service when you are there is excellent.
Chris and Ian who look after the dyno are top blokes and no matter what you have (even if its german or spainish) they are more than happy to help.
Ron.
Old Aug 24, 2005 | 10:39 AM
DanRSturbo's Avatar
DanRSturbo
Get Chris or Ian to work on your car's and you'll have no problems
A man that has a Mk 1 fezzy with a 1900 turbo lump with a supercharger and NOS can work on my car anytime
Old Aug 24, 2005 | 10:41 AM
boXXer's Avatar
boXXer
GASH!
oh yeah, saw the piccies of the blown engine @ santa pod. and he had the piston there on his desk. Looks nice though.
Old Aug 24, 2005 | 11:30 AM
tiny's Avatar
tiny
Iv been down to them in the past, just for parts, and even when they couldnt supply the bits i wanted, they pointed me in the right direction and have always been helpfull, and friendly
Old Aug 24, 2005 | 11:38 AM
RobCarden's Avatar
RobCarden
358bhp
had my 3 dr done there a few times.
its ok but a bit like dropping off your mondeo for a service at fords. no interst in the car.
Old Aug 24, 2005 | 02:33 PM
SassyRS's Avatar
SassyRS
Little Miss...
Old Aug 24, 2005 | 02:42 PM
Sexy-RS's Avatar
Sexy-RS
Wouldn't use them for our own personal cars as there is far more knowledgable people i would rather put my car in the hands of And prefer to have it live mapped ......But have taken a few shit box's there for cheap set up's as its local, sometimes they come out ok other times they aint had a clue so have ended up taking them down to grove who sort it in 5 minutes
And from others i have heard if you don't know what your on about they like to try and sell you some stuff My mate got stitched up first hand, and there was nothing wrong with his engine
