Best OIL CVH
Old 23-08-2005 | 11:10 AM
motherhupit's Avatar
motherhupit
Default Best OIL CVH
Just wondering whats the best oil to use on a 60,000 mile 1.6 cvh for under £15, i currently use Halfords 5 - 30 semi synthetic (could'nt find any 10 -30) Cheers
Old 23-08-2005 | 11:20 AM
Chipperx2's Avatar
Chipperx2
Semi Synthetic 10-40 I used on my old 1.8 CVH Is it N/A?
Old 23-08-2005 | 11:23 AM
motherhupit
Yes its NA slightly tuned so far with flowed head, modified intake manifold and K&N, gets reved quite well.
Old 23-08-2005 | 11:35 AM
Chipperx2's Avatar
Chipperx2
It says in Haynes Escort manual for the 1.6 CVH 5-30W and then as an alterantive you can use 10-40W. personally I would use the 10-40W because of the age of the engine Only my choice, bound to have others who are different
Old 23-08-2005 | 11:40 AM
motherhupit
Yeah thats why i wanted to try and find some 10-30W engines just had a Head rebuild so it doesn't leak or burn any oil.
The halfords stuff is pretty good i've seen a good improvement since i've been using it, but it does seem a little to thin. Cheers
Old 23-08-2005 | 01:45 PM
oilman's Avatar
oilman
Why set a budget and then say the best oil?
It's a contradiction in terms
If you want a reasonably priced semi-synthetic then Silkolene XTR 10w-40 costs £12.99 for 4 litres.
Its a good oil but it's not a synthetic.
Simon
Old 23-08-2005 | 04:14 PM
motherhupit
Simon
Thanks for that i'll see if i can get hold of some, it isn't a Contradiction, it simply says the best oil for under £15.
Old 23-08-2005 | 04:44 PM
mart.rs's Avatar
mart.rs
my s2 has done 107k and i got it on 93k ive been using shell helix 10w40 and to be honest id rather pay that bit extra when it comes to a decent oil! 21 squid form any shell garage! especially on older engines it works well!
Old 23-08-2005 | 05:02 PM
motherhupit
Cheers for that got another 1,000 miles left in it so i'll see what i can afford at the time.
Old 23-08-2005 | 06:17 PM
Rab's Avatar
Rab
Fucking superstar........
You shouldn't skimp on a few quid for oil. Oil of one of the most important parts of your engine.
Old 23-08-2005 | 06:20 PM
oilman's Avatar
oilman
Indeed, it's the first line of defence.
WHAT DOES ENGINE OIL DO?
LUBRICATE
Motor oil must lubricate engine components so that they will easily pass by one another without a significant loss of power due to friction. At start-up, this is especially true. As an engine sits, oil tends to run down into the oil sump. Therefore, when the engine is started, the oil must be quickly pumped throughout the engine to provide sufficient cranking speed for the engine to turn over.
Once the engine is running, engine oil must create a film between moving parts to make them "slippery" which increases power, performance and efficiency. Each different type of engine requires a certain viscosity range in order that the oil will provide an adequate film between moving parts while still flowing quickly and easily enough throughout the engine.
Some people mistakenly believe that if an SAE 30 oil provides good protection, an SAE 50 oil must provide greater protection. That's not necessarily true. If your vehicle was not designed to take an SAE 50 oil, using one may not cause more engine wear, but it will likely cause an increase in engine temperatures. This can be just as bad for the longevity of your engine as engine wear.
PROTECT
The film that an engine oil provides between metal surfaces does more than just lubricate. By keeping engine components from coming in contact with each other, a motor oil also provides protection against wear. However, there is another way in which an oil protects.
Engine oil must protect against corrosion of engine components. Oxidation of the oil and contamination via condensation and combustion by-products all cause acids within an engine oil. If these acids are allowed to come into contact with engine components, corrosion occurs and premature component failure is the result. Engine oils are designed to combat these acids.
CLEAN
If an engine does not remain clean, it does not remain efficient. Deposits within an engine gum up the works and reduce fuel efficiency while robbing your engine of performance. In addition, contaminants within an oil that are left "unguarded" can cause incalculable wear within an engine.
Any particle larger than 5 to 20 microns in size (depending upon the vehicle) will seriously damage an engine if not removed or contained. To give you an idea of how small this is, a human hair is 100 microns thick. Although filtration plays a big role in this area, the oil also has to play it's part by keeping deposits from forming within the engine and by holding contaminants in suspension until they can be removed by the oil filter.
COOL
Engine oil is responsible for a large percentage of the cooling that takes place within your engine. Your radiator is only responsible for cooling the upper portion of your engine. The rest, crankshaft, camshaft, timing gears, pistons, main and connecting rod bearings and many other critical engine components are cooled mainly by the motor oil within your engine.
Heat is generated within an engine from both the combustion process and the friction caused by the motion of engine components. As oil passes through the system it is directed onto these hot surfaces in order to carry the heat away to the oil sump. From here the heat is dissipated to the air surrounding the sump.
Simon
Old 23-08-2005 | 06:25 PM
MK5RST's Avatar
MK5RST
dont matter which oil you put in a CVH it all burns just as well
Old 23-08-2005 | 08:58 PM
oilman's Avatar
oilman
Not quite, synthetics burn more slowly.
Simon
Old 23-08-2005 | 09:58 PM
MK5RST's Avatar
MK5RST
Simon
SMART ARSE
Old 23-08-2005 | 10:40 PM
oilman's Avatar
oilman
LOL
Simon
07-10-2015 01:56 PM
Brickhouse
14
03-10-2015 08:28 PM
DAZZER
30-09-2015 09:43 PM
Fudgey
21
30-09-2015 07:19 PM
Quick Reply: Best OIL CVH
