HELP ....... fueling......
IM DESPERATE ........
will there be anyone at donnington that can help me with adjusting my fueling on saturdday or sunday?????
if not can anyone tell me the best way to set it up .. ie pressure guage etc....
have a 044 fuel pump to fit on friday night thanks to JON FOZ .. all being well that PON can source the parts tomorrow
a day earlier than i asked for ... no pressure rich
also need a set of these 071 ford plugs .. a rockercover gasket and possibly a new head ...
the fueling issue is the biggest problem i have as im starting work at 5:30 friday morning ..im hoping to get the plugs and gasket tomorrow if i can afford em
and will be leaving on friday evening .....
will post a pic of my plug in a minute ..
many thanks in advance...
had the rocker cover off tonight and have run a tap through it .. seems to have made a thread ... put a plug in it to get me home... felt like it had tightened up sufficiently aswell
my mechanic was a bit happier after he had looked at it ....
its comin apart this year to have a bit of a look at .. all the oil seals etc so might see if it needs helicoiling ....
was a bit stressed when it came out looking a bit silver on the end
my mechanic was a bit happier after he had looked at it ....its comin apart this year to have a bit of a look at .. all the oil seals etc so might see if it needs helicoiling ....
PassionFords Creator
Fuel delivery is dealt with by the fuel pressure regulator, and as long as the pump can keep up, it wont change no matter wether you fit 1 pump or ten in parallel, the pressure at the rail is maintained by the regulator, as its name suggests
Just in from work.. bed now, back there at 8:30
DaveEscos
Jun 23, 2006 12:22 PM
Graceland
23
Mar 26, 2006 06:12 PM
cfoster
Dec 26, 2005 10:46 PM
