is it an mot failure if..
Old 18-08-2005 | 04:16 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default is it an mot failure if..
you cant open the boot from the outside - ie you dont have the key to the lock, but if you climb into the boot and flick the lever it opens.
or should i tie a bit of string round it so you can open it from the drivers seat
Old 18-08-2005 | 04:18 PM
digita1dragon's Avatar
digita1dragon
dont think it needs to open mate
Old 18-08-2005 | 04:20 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ah good good, thats what i heard, so was just checking
digita1dragon
http://www.motuk.co.uk/manual/contents.htm
Old 18-08-2005 | 04:21 PM
Graceland's Avatar
Graceland
Team HOTHOT!
boot lock is not part of the MOT
however, reasonable access methods must be available incase of an emergency - IE - door handles
AndyBlackFRST's Avatar
AndyBlackFRST
Thought as long as there was 1 way to enter the car then it would be ok.
Old 18-08-2005 | 04:23 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cool, cheers DD, dont say owt about the boot so fingers crossed lol
Old 18-08-2005 | 04:27 PM
S1 JOHN's Avatar
S1 JOHN
depends on the tester they like to check boot floor rear suspension easiest way is just to pop it just before it goes into the tesing station if not they may just write an advisery note saying they couldnt check in the boot
Old 18-08-2005 | 04:30 PM
Moose 130's Avatar
Moose 130
Load Security
1. Check that any bootlid. tailgate, loading door, hinged tailboard or dropside is or can be secured in the closed position.
Does not say you have to be able to open it but;
2. Refusal to test
g. A proper examination cannot be carried out because any door, tailgate, boot, engine cover, fuel cap or other device designed to be readily opened cannot be readily opened.
Old 18-08-2005 | 04:33 PM
pee vee's Avatar
pee vee
dont think anyone has ever opened my boot in an MOT fudgery-gar!!
01-11-2015 06:53 PM
gcfcos
59
06-10-2015 05:04 PM
Quick Reply: is it an mot failure if..
