HELP NEEDED ASAP. PLEASE HELP
Old Aug 15, 2005 | 05:16 PM
tansey's Avatar
tansey
Default HELP NEEDED ASAP. PLEASE HELP
i was driving down the road and the battery light came on and then the car cut out.the engine turns over but there is no power to the coil or no power to the fuel pump so it wont run.any ideas what the problem could be???? tried a new alternator but still the same. ANY IDEAS ?
Old Aug 15, 2005 | 05:22 PM
georgie1's Avatar
georgie1
could be a loose wire or blown fuse or relay to the fuel pump
Old Aug 15, 2005 | 06:15 PM
tansey's Avatar
tansey
bttp
Old Aug 15, 2005 | 06:19 PM
tansey's Avatar
tansey
tried all fuses but how do i check the realys? checked all red wires to positive side of the battery wiggled all wires on the 3 block conecters on the back of the engine. im baffled!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 15, 2005 | 06:30 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Ignition amplifier is my bet, if this goes, it wont give power to coil or fuel pump
Old Aug 16, 2005 | 12:36 AM
tansey's Avatar
tansey
cheers mate will try and borrow one a these tommorow and see if it is that
Old Aug 16, 2005 | 12:46 AM
vroooom ptssssh
It Wasnt Me!
good luck
Old Aug 16, 2005 | 12:53 AM
tansey's Avatar
tansey
cheers mate. the car had an awful misfire for about a month or so and finally got the misfire sorted ready for national day................................... and now this!!!!!!!!!!!! no need at all. cheers
Old Aug 16, 2005 | 01:22 AM
vroooom ptssssh
It Wasnt Me!
right pisser, they ALWAYS break before show's/track days
Old Aug 16, 2005 | 12:16 PM
tansey's Avatar
tansey
just tried the igition amplfier and the map sensor and still no luck.any more ideas please?
Old Aug 16, 2005 | 12:43 PM
vroooom ptssssh
It Wasnt Me!
crank pisition sensor? dunno if that would stop the spark and fuel though
Old Aug 16, 2005 | 01:10 PM
tansey's Avatar
tansey
that was checked the other week when i had that misfire and that was ok . cheers though
Old Aug 16, 2005 | 03:11 PM
tansey's Avatar
tansey
bttt
Old Aug 17, 2005 | 10:25 AM
tansey's Avatar
tansey
bttt
Old Aug 17, 2005 | 10:40 AM
Neil S's Avatar
Neil S
The fuses and relays for the fuel pump and ECU are behind the dash in the passenger footwell near the transmission tunnel. Try those!
Neil.
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
