Steering problem s2
Old Aug 10, 2005 | 08:07 PM
Trev's Avatar
Trev
Default Steering problem s2
Ok peeps new prob - have got my MOT finally however after replacing the bottom bush in the column the steering is heavy and doesnt retunr to wheels straight when you release the wheel after turning?????
Any ideas?
Trev
Old Aug 10, 2005 | 08:49 PM
Trev's Avatar
Trev
bttt
Old Aug 11, 2005 | 10:34 AM
JesseT's Avatar
JesseT
It's propably mislocated. Quite common to get it a bit wrong.
Old Aug 11, 2005 | 03:08 PM
Trev's Avatar
Trev
BTTT
Old Aug 11, 2005 | 03:12 PM
zvhturbo's Avatar
zvhturbo
Theres a small plastic bush where the column goes through a casing.
You must make sure this bush is currectly aligned when tightning the steering wheel nut.
Matt.
Old Aug 11, 2005 | 05:21 PM
Trev's Avatar
Trev
cheers mate will double check
Trev
Old Aug 14, 2005 | 09:07 PM
Rick's Avatar
Rick
up, as i have same prob. When i took of the steering wheel, there is a plastic bush resting on top of the coloumn, over the hex. Should this be there?
Old Aug 15, 2005 | 01:15 PM
JamboRS's Avatar
JamboRS
focus rs 1672
yes mate it should be there
Old Sep 29, 2005 | 02:50 PM
Rick's Avatar
Rick
Still got this problem. Do i have to remove top part of rack to get at this bush?
Old Sep 29, 2005 | 09:00 PM
Trev's Avatar
Trev
yep - need to pull out the tube that is around the rack then slide the bushes up
Old Sep 29, 2005 | 09:16 PM
Rick's Avatar
Rick
Sorted it today! What a fookin pain in the arse! Last year someone tried to steal the car, and thats when they must have dislodged it. Sorted it this afternoon. It's cured all sorts of handling problems, im well chuffed
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
DHMC
Ford Fiesta
Sep 20, 2015 06:47 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
